Andrew's Sterlingsilber 90 325iS -> 318iS
  • Andrew325is
    • Jan 2008
    • 1212
    #151
    Originally posted by rjsimeon
    Damn, Andrew! I'm gonna need that POC for those wheels! I'm jealous! Congrats. I know you've been waiting for a while. Looks good!
    What does POC mean?
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
    • jeenyus
      • Aug 2011
      • 2064
      #152
      Originally posted by Andrew325is
      What does POC mean?
      People of Color? Also this emoji is racist i just realized...
      • Andrew325is
        • Jan 2008
        • 1212
        #153
        Yeah, I noticed that too. This one isn't cool either. :hitler:
        • rjsimeon
          • Jan 2019
          • 97
          #154
          Yeesh, didn't realize I was using military lingo. Point of Contact.
          • Andrew325is
            • Jan 2008
            • 1212
            #155
            Well they only had 1. They said their friend has one too, but they haven't got back to me on that. I would like 1 more. It would be nice to have 2 really straight ones up front. Can't stand feeling vibration in the steering wheel. :)
            • getouth
              • Jan 2010
              • 3343
              #156
              sub'd quality content here! I dig it!
              FEEDBACK:
              http://www.r3vlimited.com/board/showthread.php?t=316212
              BMWCCA #398608
              IG @yagayo38
              "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
              • Andrew325is
                • Jan 2008
                • 1212
                #157
                Here's a few photos I took. I installed the door cards.
                • Jokester
                  • Sep 2016
                  • 1818
                  #158
                  Gorgeous.
                  • Andrew325is
                    • Jan 2008
                    • 1212
                    #159
                    I'm starting to gather parts to renew the brakes. I got a pair of rebuilt front ATE calipers. The ones on there now are Girling. I read the ATE ones can use the brass bushings, but I've also read mixed reviews on those so maybe I'll just use the stock bushings. Since I have 15" wheels I've thought about getting a little bigger brakes too. I could get E30 M3 calipers for the rear and run the Z1 rotors, but then the bias might not be ideal without upgrading the fronts. The Z1 had regular E30 brakes on the front, but I'm not sure all the engineering/reasoning for that with the larger rear brakes. So I think I'll just keep the rear brakes stock, especially since regular E30 rotors are easy to come by and inexpensive. I think I might try the cryogenic rotors. I read they are less likely to warp and last longer. I'm a little undecided on the brake pads. I might try the new Centric PQ PRO pads. I haven't read any reviews for them yet though.
                    • ATL_E30
                      • May 2017
                      • 240
                      #160
                      Man those look clean, where did you snag them?
                      • Andrew325is
                        • Jan 2008
                        • 1212
                        #161
                        RockAuto
                        • Andrew325is
                          • Jan 2008
                          • 1212
                          #162
                          Anyone want to go for a swim? :P
                          I guess I'll have to get in the trunk and have someone spray water on it to see where it's leaking in. I hope they let me out after haha.
                          • nrubenstein
                            • 3148
                            #163
                            RockAuto
                            The one bad thing about centric rebuilds (I use them myself) is that they are completely uncoated. In other words, if you don’t want a rust colors caliper after the first time they get wet, you’ll need to paint or coat them.
                            2002 BMW M3 Alpinweiß/Black
                            1999 323i GTS2 Alpinweiß
                            1995 M3 Dakargelb/Black
                            - S50B32/S6S420G/3.91
                            1990 325is Brilliantrot/Tan
                            1989 M3 Alpinweiß/Black
                            • e30austin
                              • 15382
                              #164
                              Make sure to unclog the factory vents, on each side of the rear valance, about four inches behind the rear tire, directly in the center of the tray. Looks almost like a "v", and they are usually packed full with dirt or factory undercoating.
                              • Andrew325is
                                • Jan 2008
                                • 1212
                                #165
                                Hey, thanks for the tip!
