Andrew's Sterlingsilber 90 325iS -> 318iS
  • Albie325
    • Jul 2016
    • 515
    #211
    Car looks great, lots of good work here in the last few months. Congrats, glad you're out enjoying the car again!
    '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
    Albie325 Build Thread | Albie325 COTM Jan 2021
    • Andrew325is
      • Jan 2008
      • 1212
      #212
      I weighed the car on the truck scale nearby and it's ~2,700 lbs. So that makes it the same weight as a Z3 1.9 and about 100 lbs more than a stock original 318is, due to the 325is chassis sound deadening, larger fuel tank, and other options like CC, OBC, & check control. The M44 will make up for that extra weight and it should have the same performance as the Z3. Car and Driver achieved 0-60 in 7.9 seconds with their Z3, so it might actually be a hair faster than an original 318is. Either way, it's right in there. Here are power diagrams comparing the E30 M42 with E36 M42 and also the E36 M42 versus the M44. The M44 has quite a bit more mid-range power compared to the E30 M42.
      Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
