318i content
  • fresh_TD
    • Aug 2013
    • 2457
    #46
    Today I applied a coat of Collinite 845. Best wax in the game, IMO. Super easy to apply and buff out. It's like butter.
    Sent from my Pixel 3 using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • BMWBrat
      • Jan 2019
      • 59
      #47
      Looks great! Unless you just love waxing your car, you might want to consider getting it ceramic coated. Best thing I ever did for mine. You'll never wax your car again and nothing sticks to it. See?
      Sent from my iPad using Tapatalk
      • getouth
        • Jan 2010
        • 3343
        #48
        ^^ This is true!
        FEEDBACK:
        http://www.r3vlimited.com/board/showthread.php?t=316212
        BMWCCA #398608
        IG @yagayo38
        "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
        • fresh_TD
          • Aug 2013
          • 2457
          #49
          hardware came in from FCPeuro, to refresh the LSD I picked up last week.
          • mike.bmw
            • Dec 2015
            • 1760
            #50
            Nice!
            Some of the new diff drain/fill plugs have a built-in rubber o-ring. I'm not sure if you need to use the crush washers if your plugs have the o-ring.
            What fluid are you going to use?
            • fresh_TD
              • Aug 2013
              • 2457
              #51
              Originally posted by mike.bmw
              Nice!
              Mike, you're right. I just looked again and they do have a built in green o-ring on them. I'm going with redline 75w90
              • e30RS
                • Mar 2019
                • 437
                #52
                Sorry a little late to the thread that wax job was aaaaamazing. Car looks fantastic.
                • Jokester
                  • Sep 2016
                  • 1818
                  #53
                  Ceramic coatings aren’t worth the money imo. Unless you want to go all in and buy silica based sprays and PH neutral soaps, you will get the same durability out of a proper sealer and wax.
                  845 and Power Lock are my go to, and I use bead maker as a drying aid whenever I do my weekly washes. This combo destroys about 75% of the ceramic coatings out there, and is far cheaper and safer
                  • fresh_TD
                    • Aug 2013
                    • 2457
                    #54
                    +1
                    • fresh_TD
                      • Aug 2013
                      • 2457
                      #55
                      Today I replaced front rotors/pads. I'll knock out the rears tomorrow.
                      • fresh_TD
                        • Aug 2013
                        • 2457
                        #56
                        Quick 5min job today. Replaced the original old style timing chain tensioner with the new style tensioner.
                        Old on the left, new on the right (still compressed)
                        • fresh_TD
                          • Aug 2013
                          • 2457
                          #57
                          370mm Tech 2 wheel installed.
                          • mike.bmw
                            • Dec 2015
                            • 1760
                            #58
                            Nice! Less than a week until The Vintage!
                            • robrez
                              • Jul 2008
                              • 3376
                              #59
                              Great work on this sedan. Looking forward to your thoughts on the 3.64 when it's installed. I considered a 3.64 for my m42 sedan but instead went with a 3.91 lsd to replace the 4.10. I've yet to install mine, but depending on your thoughts, I might try a 3.64 instead.
                              January 2012 COTM
                              • fresh_TD
                                • Aug 2013
                                • 2457
                                #60
                                robrez, my previous 318 I had a S3.73. Loved the ratio. 3.64 is very close to that, so I'm sure I'll be very happy with it.
