318i content
  • rbmwiv
    • Aug 2017
    • 57
    #31
    Super clean find. Interior looks like it was just purchased new. Haven’t seen cloth that nice in a long time. Also a trick I have used to upgrade the headlights is just buy the inner and outer from a e30,32,& 34 all use the same ellipsoid light lenses housing. You can find ones with broken tabs for next to nothing on eBay. After that just a little trimming of the plastic and they will set into the sealed beams buckets. It’s a lot cheaper than buying a set.
    Great car just passing on some of the tricks I picked up over the past 25 years. Good luck with it, and May it bring you nothing but joy.
    • fresh_TD
      • Aug 2013
      • 2457
      #32
      Thanks for the tips, I appreciate it.
      Sent from my Pixel 3 using Tapatalk
      '91 318i (Alpine) - daily
      '88 325ix (Zinno) - drive here and there!
      • fresh_TD
        • Aug 2013
        • 2457
        #33
        The 318i came without fog lights. I reached out to forum member (td325ic) who sells refurbished fog lights for $150 a set. They came in yesterday, and I installed them today!
        • fresh_TD
          • Aug 2013
          • 2457
          #34
          They other day I washed and clayed the car. This morning I applied Meguiars #7 to feed oils back in the single stage paint. I also replaced all accessory belts with Gates brand belts. The contitech belts on the car were showing cracks and looked dry. I also removed the BMW mud flaps the car came with.
          • mike.bmw
            • Dec 2015
            • 1777
            #35
            This car just keeps better and better. Great work!
            • getouth
              • Jan 2010
              • 3343
              #36
              Looks great! Sub’d
              Drive Tastefully!
              FEEDBACK:
              http://www.r3vlimited.com/board/showthread.php?t=316212
              BMWCCA #398608
              IG @yagayo38
              "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
              • fresh_TD
                • Aug 2013
                • 2457
                #37
                Originally posted by getouth
                Looks great! Sub’d
                Drive Tastefully!
                Thanks!! It's definitely a driver.
                • fresh_TD
                  • Aug 2013
                  • 2457
                  #38
                  Wiped the car down, taped the trim and letting the car soak with another layer of Meguiar's #7. I will do this a few more times before I cut, polish, seal and wax the paint.
                  • eternal24k
                    • Jul 2017
                    • 507
                    #39
                    looks great,
                    • AWDBOB
                      hooptie connoisseur
                      • Aug 2013
                      • 4503
                      #40
                      This thing looks awesome! You should post a writeup on how you wired in that keyless entry ;)
                      • IceWhite
                        • Jan 2015
                        • 945
                        #41
                        For cleaning or for good?
                        If, for good, why? (Just Curious)
                        1990 325i
                        2004 330i Individual 6-speed
                        • fresh_TD
                          • Aug 2013
                          • 2457
                          #42
                          For good.. just not my thing.
                          • IceWhite
                            • Jan 2015
                            • 945
                            #43
                            ^Ah ok. Thought as much.
                            BTW, Your car looks really great. I wish mine could look as good as that.
                            1990 325i
                            • fresh_TD
                              • Aug 2013
                              • 2457
                              #44
                              This 318i came with an open 4.10 small case diff. This morning I picked up a small case 3.64 LSD. This diff came out of an early model 318i. Plans are to clean, paint, reseal, fresh fluid and install. Will be nice to cruise on the hwy with this ratio.
                              • fresh_TD
                                • Aug 2013
                                • 2457
                                #45
                                Today I replaced spark plugs, valve cover Gasket and painted valve cover.
