Bad ass.
Repaint/Alpha-n/and more... E30 CONTENT
more videos please. by the way is the box a 15cm or the bigger 17cm version?Comment
My fucking Innovate system has never worked correctly. Yours I see is working well. Looks good!!!
Mariano
Ted i need to do a oil filter relocation as well for my box, did you use the summit kit?Comment
Mariano run it disconnected from the MAXX. Just run the MAXX with lamda off and then connect the laptop to both the innovate logger software and the maxx. It works fine for me. Do you have an LC-1?PNW Crew
90 m3
06 m5Comment
bought a Perma-cool kit from summit, but it's better to just source the parts individually.
I'll post all of the p/n's but the way I'm doing it is just having the base plate/filter housing from perma-cool. I then am going to get NTP fittings and line from a local supplier. Basically, it will look and function like aeroquip with braided lines for about 120$ total for everything include custom bracket.
I recommend an a/o seperator as well - ditch those crank case vapors! :)PNW Crew
90 m3
06 m5Comment
Yan I'll make a whole thread about it later, but cliff notes:
Ted do that. pioneer a kit and make it clear and simple for all. Ill be looking forward to reading up on it. be as specific and clear as you can bro. and lots of pics.Comment
Looking forward to your write up on the filter relocate Ted.
I have not found a solution I like yet but your's is the closest. I want to see if i can fit the filter along the frame rail pointed downward. This way, no oil leaks all over the fenders when you replace the filter :)Chris
90 Corrado/91 M3/01 M5
First post in this thread was 3/29/07 been over a year, im sure you are aching to take it for a nice long drive.Comment
