My Brother's Summer Restoration Project
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    My brother, Josh, and I have been spending the past few weekends and a couple Thursdays slowly rebuilding my brother's 1989 325i.
    We didn't plan on starting the project so soon but when his water pump went out we decided to get an early start.
    Everything pictured is leading up to how far we got this past weekend. Hopefull it will be finished and fired up by this weekend.
  • ///Mayhew
    • May 2007
    • 285
    WOW awsome job on the motor that thing looks great!
    1989 325i MT2/4dr
    My life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather i will skid in broadside,thoroughly used up,totally worn out and loudly proclaiming....WOW..What a ride!
    • MikeE30325i
      • 2356
      wow, that has to be the cleanest engine i have ever seen. God damn.
      excellent job.
      • SnowFiend
        • May 2007
        • 106
        you could eat off that thing! looks sick, man.
          • 34844
          looks fantastic! are those bavauto longtubes? any internal mods, or just a stock refresh?
          • e30lyf
            • May 2007
            • 4552
            Sweeet, What kind headers is that?
            - Fercy -
            Classic BMW Specialists
            Santa Clarita, CA
            www.BimmerHeads.com
            • markseven
              • Sep 2006
              • 5327
              That's a work of art.
              I Timothy 2:1-2
              • RobertK
                • Jun 2005
                • 5864
                Actually they are the 2nd gen Budget Beater stainless long tube headers, which I must admit are a pretty damn good deal for $260 shipped. My only complaint was that I had to grind down and polish the welds on the inside of one of the headers because they were too thick.
                As far as modifications here is everything I can remember.
                Engine
                New valve guides / seals
                5 Angle Valve Grind
                Aggressive Porting on intake side
                Aggressive Port and Polish on Exhaust side
                Port matched Intake Manifold / Gaskets
                Metric Blue Head Bolts
                Every gasket reaplced
                Every hose replaced
                Every belt replaced
                Every seal reaplced
                M30 AFM
                17.5# Injectors
                Spal 2.05 Inch 1300CFM Electric Fan
                AKG Urethane Engine Mounts
                Exhaust
                2nd Gen. BB Headers
                (Rest of Exhaust Setup is Undecided)
                Suspension
                New Uro Control Arms
                Urethane Offset CABs
                E36 Tie Rods
                95 M3 3.0 Steering Rack
                Modified Rack Knuckle w/ Aluminum Disc
                Transmission
                Complete Getrag 260 5 Speed Swap
                Custom Stage 1 Clutch Disc built by World Clutch
                New Sachs Pressure Plate & TO Bearing
                Lightened Single Mass Flywheel to 12lbs / Resurfaced
                New clutch master & slave cylinders
                New clutch metal hydraulic line
                New PVC coated steel slave hydraulic line
                AKG Urethane Tranny mounts
                I'm sure I'm forgetting much more.
                • CleanAzzE30z
                  • Jan 2004
                  • 11794
                  Wow..... thats really nice..
                  Mariano
                  • Mako18
                    • Jul 2006
                    • 688
                    This is a very good example of how to do things "the correct way!!" great job looks awsuuummmee.
                    • backtrail69
                      • Jul 2005
                      • 4471
                      Awesome. Way things are supposed to be done.
                      :: PNW Crew ::
                      '87 325 4dr, '74 2002
                      • euroshark
                        • Apr 2006
                        • 3491
                        It makes so much sense to paint the engine compartment black! I have been planning this for both of my cars when they get painted... it looks bad ass, is easily touched up, it's just so hardcore. Nice work!
                        • whiltebeitel
                          • Apr 2007
                          • 2098
                          That's seck. I love the head cover and the headers. ;)
                          '89 325i track sloot
                          '01 530i daily
                          -Enginerd
                          • Huff
                            • 2488
                            Did you paint the engine bay while you had everything out?
                            • RobertK
                              • Jun 2005
                              • 5864
                              Yeah.. we degreased everything, pressure washed it, scoured the finish and then painted it some black semi gloss Duplicolor 500 degree high temp rattle can paint.
