so my twin turbo vert...
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Originally posted by eyagel
    holy batman that looks fast..
    When i crashed, i was thinking of dropping my M30 turbo into a vert. 90% of the people on this forum said that it was way too dangerous due to rollover. Stick with a coupe they said.
    I hope that he can handle the power better than I did.
    Be careful
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • Wiglaf
      • Jan 2007
      • 1513
      Originally posted by smonkbmw
      why not move the battery to the trunk and turn the wastegate to that area. as opposed to over the valve cover? also possibly moving the coil to that area? just to clean things up a bit of course
      the best would have been if the internal wastegates weren't welded shut.. that whole thing seems pretty unnecessary. i think it was set up this way so that boost control could be added. at this point i'm not gonna mess with that.. but at this point i know enough to roll my own setup for next time. :)
      i do want to move the battery, it's on the list. freeing up that tray would be pretty sweet, and there's just too much heat around there for it anyways.
      i am thinking about a rollbar for it...
      Originally posted by u3b3rg33k
      If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
      • MikeE30325i
        • 2356
        cabrio with a rollbar would look tits with the top down.
        • sticksdaman
          • Apr 2005
          • 2987
          rollbar hardtop and some susp work and you are golden oh and i hat ethose wheels but you like them so my opinion counts for nothing
          love what you did with the place
          keep it shiny side up
          Originally posted by ebelements
          Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
          • Wiglaf
            • Jan 2007
            • 1513
            i had them already, it was convenient. i want different ones, something with deep lip on them. I'll wait till after i have the rest of things fixed up before i splurge on wheels though.
            • Aveman
              • Sep 2006
              • 81
              Originally posted by Wiglaf
              yeah waleed was pretty helpful with this. there's a few things he did with this setup that i don't really understand but most of them are water under the bridge since i went with megasquirt.
              i used a new headgasket with metric blues. it should hold up ok if what i've read works out in reality.
              btw he told me it would only be pushing 8 or 9psi, either his meter was off or the wg spring changed somehow
              Yeah it would never really go more than 9 psi you using the same gauge he had?
              • Wiglaf
                • Jan 2007
                • 1513
                megasquirt's MAP sensor.. i didn't bother with the analog gauges. just the egt for a bit to get some confidence but that was temporary. now it's just an AFR meter (i got a wideband, his was narrow).
                the exhaust is pretty damn loud, but :twisted:
                • loonibab325i
                  • Dec 2005
                  • 770
                  haha what a SICK setup.
                  Respek.
                  s52 0-150mph & more http://www.youtube.com/loonibab325i
                  • Aveman
                    • Sep 2006
                    • 81
                    It would have probably spiked pretty high if the tiny little internal wastegates were left on. Take her to the track, you have to beat 13.9 at 103 MPH with a 2.6 60ft, slipping clutch and stock engine management with FMU.
                    http://media.putfile.com/139103mph :up:
                    I'd love to see this setup get into the low 13s or high 12s I think it's easily doable. He ran a 13.8 at 105 I beleive once, with another shitty 60ft and bad clutch.
                    • Digitalwave
                      is a poseur
                      • 6301
                      Crazy setup... I can't believe you drive that on stock suspension. Are those real TE37's?
                      RISING EDGE
                      • Mystikal
                        Wheel Fitment Expert
                        • 9602
                        I saw Waleed's car with this setup, crazy stuff. I was tempted to buy the damn thing, it went for such a good price for a running, proven kit. Glad to hear it worked for you.
                        -Jay
                        • Wiglaf
                          • Jan 2007
                          • 1513
                          real te37's? i don't actually know what you're talking about. wheels?
                          they weren't expensive, i had them on my honda.
                          so i had the wg hooked to the 1st turbo, the second was capped. when i y'd them together it stays more around the 9.5psi mark, less bouncing around.
                          the cabby weighes more than the sedan, i'm about ready to hit the strip but i'd have to be making more power to match that time.
                          just put the 2.93 LSD in yesterday, that'll help :D
                          still trying to get an intake filter together, might hack into behind the bumper (area under the headlights) and open the bottom of the bumper up for some cold air sourcing, not 100% sure yet. it's pretty packed in there.
                          • rsafier
                            • 164
                            Yeah pulling that time off on street tires is going to be more of a problem.
                            For reference on a 2.93 with the old motor (somewhere around 2.93s) best was a 14.3 @ 98. The new motor with the 3.25s and over 300rwhp dyno verified all i could do was 14.4 @ 110. Both were on autox suspension and very stiff sidewall 205 street rubber. Slicks now that would be into the mid 12s. Still going for the MPH number should give you a cheap way of getting a ballpark on the power level. Let me know when your going to the track, I might show up too with the 318is just for fun. Even if I put the 285 R-compounds on the turbo car I'm not dropping below 13s as they just don't work well for straightline off the line traction, plus the car is too stiff for that stuff at this point.
                            SM 19 - Serial Destroyer of Cars
                            Turbo '89 325i - It lives! Now the question is for how long?
                            2SlowRcing.com
                            • Wiglaf
                              • Jan 2007
                              • 1513
                              well I moved the battery to the trunk. that's good for an extra 40HP easy, should put me in the 12's. :D
                              j/k
                              but there was a weight in the trunk that i yanked out, it must have been over 60 lbs.
