Finally back into an e30: ‘88 Alpine on Blue 325ic cruiser build
  • Mastrcruse
    • Sep 2005
    • 5340
    #166
    Finishing up the Wastegate plumbing for the tru boost setup and positioning of the downpipe and Wastegate outputs.
    • Mastrcruse
      • Sep 2005
      • 5340
      #167
      All fully wired and plumbed. The front end and motor are done! Now just need to run gauges to power/ground and finish up ECU install. On the the rear!
      • Mastrcruse
        • Sep 2005
        • 5340
        #168
        Rear end rebuild - let’s get at it. Need to get subframe to powder first.
        • zwill23
          • Jul 2015
          • 615
          #169
          I don’t see a fuel filler hose in that smorgasbord of parts! I’d replace that while you have the subframe out if you haven’t already.
          Getting close!
          • Mastrcruse
            • Sep 2005
            • 5340
            #170
            Getting close!
            Oh it’s in there haha. It’s in the hutch thing.
            • Mastrcruse
              • Sep 2005
              • 5340
              #171
              Started the deconstruction of the rear. It’s been going pretty well until I got to the passenger side axle shaft. Won’t budge with heat, beating the crap out of it and other methods.
              • Mastrcruse
                • Sep 2005
                • 5340
                #172
                Got the subframe powdered and will put it together this weekend. I have all new parts and am working on getting the original rear subframe out of the car. It’s getting there!
                • kid325e
                  • Sep 2007
                  • 6422
                  #173
                  The rear subframe looks incredible. Going to be a beauty to see anytime you're under the car - is it going to stay that "shiny"?
                  clutchCTRL!
                  Move with a purpose.
                  - 1991 325iX 4dr/5spd
                  - 2000 323i AT
                  2016 Mazda CX3 Sport AWD
                  • Mastrcruse
                    • Sep 2005
                    • 5340
                    #174
                    I hope it all stays shiny.
                    Got the original subframe out and it was a pain in the ass. Had a piece of the bushing break into the chassis so need to chisel it out.
                    • Mastrcruse
                      • Sep 2005
                      • 5340
                      #175
                      All new hardware, paint, speed sensor for the diff. Have the wires for the rear all newly wrapped. Getting there! Subframe will go back in this weekend.
                      • Mastrcruse
                        • Sep 2005
                        • 5340
                        #176
                        Finally was able to continue to work on the car. Some progress this weekend.
                        Got a new heat shield in to get rid of all the nasty rusted stuff.
                        Got the diff done and the subframe ready to go back in. Didn’t because I need some new brake hard lines.
                        Had a mobile car audio guy come out and hooked up the gauges and the new head unit.
                        • Mastrcruse
                          • Sep 2005
                          • 5340
                          #177
                          Rebuilding the axle shafts. Need to source one since I mushroomed the end of one of mine while removing it.
                          • Mastrcruse
                            • Sep 2005
                            • 5340
                            #178
                            Alpine installed. Alpine has customized colors so I think I got it matching!
                            • Conrad311
                              • Oct 2009
                              • 370
                              #179
                              must be chilly there!
                              I have a kenwood head unit that has the same deal, the color is just about right, but I wish the lcd wasn't blue..
                              "In God we trust. All others must bring data." -W. E. Deming
                              /// 1987 325is /// Project Thread
                              Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.
                              • Mastrcruse
                                • Sep 2005
                                • 5340
                                #180
                                Yes it is haha. Front end isn’t on yet so not temp sensor installed.
