Finally back into an e30: ‘88 Alpine on Blue 325ic cruiser build
  • Mastrcruse
    • Sep 2005
    • 5340
    #136
    Getting the intercooler fitted up.
    things that need to be finished over the next week -
    IC mounted
    Gear shift install
    Steering joint and rack out back in
    Car sat down and torque of the front suspension
    gas lines hooked up
    starter wired up
    turbo oil feed and return line finished up
    final tightening of clocked turbo
    final tightening of Wastegate and downpipe
    fitting and install of IC piping
    • Mastrcruse
      • Sep 2005
      • 5340
      #137
      Z3 rack is in. That was not very fun doing it alone but it’s in. Tightened suspension down and gonna put it on the ground for the first time in months to load the suspension - then I’ll final tighten. Garagistic spacer kit worked out well but a lot of modification to make it all fit.
      Got the clutchline in front condor and going to wrap up the gearshift tomorrow.
      • Mastrcruse
        • Sep 2005
        • 5340
        #138
        Anyone know whether the rear gearshift mount goes in the bottom or top hole?
        • Mastrcruse
          • Sep 2005
          • 5340
          #139
          New front end looking so good! Letting the car rest (for the first time in months) on its own weight and then will final tighten front suspension items. The front seems to be considerably lower than the back now - it’ll be all new after I’m done with front suspension and motor items.
          • Mastrcruse
            • Sep 2005
            • 5340
            #140
            With everyone’s help, I got the gearshift in and all buttoned up. The Z3 shifter is SO much tighter than the OEM action.
            • Mastrcruse
              • Sep 2005
              • 5340
              #141
              New windshield and finally got rid of that nasty windshield surround for a new black one.
              • Mastrcruse
                • Sep 2005
                • 5340
                #142
                Intercooler and piping all aligned. Final tightening of turbo clocking. Got the power steering stuff back in and hooked up (a bit of a PITA). Final torqued the front suspension.
                Z3M radiator is on its way along with a new fan clutch and fan.
                This weekend Radiator will be installed, run the AFM lines to a gauge on the steering column, run ICV to IC tubing, and run vacuum lines.
                • 2mAn
                  Señior Mod
                  • 21024
                  #143
                  dude, you are NOT messing around here.
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • jeenyus
                    • Aug 2011
                    • 2064
                    #144
                    turbo M20, the dream.
                    • Mastrcruse
                      • Sep 2005
                      • 5340
                      #145
                      It’s going together pretty well. Moving to the rear full suspension rebuild while finishing up the front and motor. Only thing I’m worried about conquering is the front valance work. Gonna be cut up bad and need to have patience with it - which I don’t have much of haha.
                      I’ll tell ya - nearly everything is new - even all the bolts- on this car which I’m cool with because it’s less potential failures. Only thing I’ll regret not doing is studding the head, new head gasket, and new head but I’ll do that once the first one blows.
                      • Mastrcruse
                        • Sep 2005
                        • 5340
                        #146
                        I also wish I had a larger garage lol...but that’s everyone I’m guessing.
                        • Mastrcruse
                          • Sep 2005
                          • 5340
                          #147
ID:	9895934 Was able to find tube for the IC tubing to the ICV. Summit is local, thank God, and I had them just give me everything that was 3/4” and had a 90 in it. Worked out after a little trimming and flipping the ICV upside down.
                          • mike.bmw
                            • Dec 2015
                            • 1777
                            #148
                            I'm really enjoying this thread. Great work.
                            • Mastrcruse
                              • Sep 2005
                              • 5340
                              #149
                              Rally road gauge pod installed. Waiting on a tru boost setup and will wrap wiring and ecu stuff up. Also waiting on Stim Tech vacuum manifold.
                              • Mastrcruse
                                • Sep 2005
                                • 5340
                                #150
                                Z3 radiator in with new fan blade and fan clutch.
