TCS retrofit
  • DatUtahGuy
    • Jan 2007
    • 3146
    #31
    are you using the same(75W90) in your tranny?
    YOUTUBE: AR Perez
    If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
    • Wh33lhop
      • 11705
      #32
      Whatever the previous owner put in.
      Actually, knowing the previous owner, whatever the previous previous owner put in.
      I'm going to put some redline in there but I'm not sure if I want to go MT90 or MTL and I haven't done much research on the matter.
      paint sucks
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        #33
        fixed
        Then I am hardcore, even with a fractured elbow.
        • atomic
          • Jun 2007
          • 5691
          #34
          Originally posted by bumblebeemer
          wheres the enviromental hazardous waste spill citation associated with that LSD upgrade lol
          • FredK
            • 14762
            #35
            Originally posted by YAN-3
            @ night ? for real?
            The most involved thing I think I've seen on the internet was an engine swap that was done completely under the cover of darkness (city regulations), in some guy's front yard in NYC. It was an Mercedes AMG V8 swap, and the guy doing the swap was a master tech at a dealer, so they did it probably in the same time as this diff swap. jkjkjk :p
            Originally posted by Wh33lhop
            With the torque that those top bolts were applied I needed room to see and to use a cheater bar. Took me like 3 hours to get the top bolts off including trips to the hardware store for a 19mm wrench and cheater bar. Then the driveshaft nuts were a whole different story...
            I use a mini 2lb sledge and a cheap 19mm wrench to remove the top bolts. The driveshaft nuts come off a lot easier if you heat them up with a propane torch. The torch probably isn't necessary for a CA car... you just need a hammer and a 16/17mm wrench. :p
            Congrats, though. Every time you do something on your car, you learn for the next time how to do things faster. The first time I did a diff swap it took all night. It probably takes an hour and a half for me now, mostly because I work alone and have to toggle the e-brake to torque the output flange bolts myself.
            • JGood
              • Jan 2004
              • 7959
              #36
              I see where you got your user name.
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
              • Wh33lhop
                • 11705
                #37
                That's nothing. ;)
                paint sucks
                • JGood
                  • Jan 2004
                  • 7959
                  #38
                  That's nothing. ;)
                  haha, 20 feet of wheel hop is nothing!? Any time I get wheel hop I lift, it feels like the world is ending!
                  • Wh33lhop
                    • 11705
                    #39
                    20 feet at 30mph isn't too long, but I meant the severity--it was pretty mild. My old car would have richter scale wheelhop.
                    Guess I need new TABs and RSMs...
                    paint sucks
                    • Wh33lhop
                      • 11705
                      #40
                      I needed a 24" cheater bar and a 17mm wrench--4lb sledge wasn't enough. The wrench would keep popping off because of the taper on the driveshaft nuts so I couldn't kick it or use a hammer very effectively. I also used a cheater bar and 19mm wrench on the subframe bolts and wound up with a zombie finger.
                      Yeah well not only do I have the "proper" tools but now the bolts aren't as impossibly tight as they used to be so I could probably do it in under 2 hours now.
                      paint sucks
                      • JGood
                        • Jan 2004
                        • 7959
                        #41
                        Will that help? Both my track and street car have 250k+ mile TA and subframe bushings, and both get wheel hop like crazy, whether I am feathering the throttle in the track car with r-comps or if I do a full clutch drop in my street car with shitty all seasons.
                        • Wh33lhop
                          • 11705
                          #42
                          In theory anything you can do to get rid of play in the rear suspension should help. How much it will help I can't really say as I don't have experience in that regard. I just figured replacing the bushings with new or stiffer ones would do the trick or at least help with it.
                          paint sucks
                          • JGood
                            • Jan 2004
                            • 7959
                            #43
                            Yeah, true. I think I may try it too. I get a clunking as well in both cars if I'm coasting in reverse and hit the brakes. It just looks like such a PITA to do those bushings...
                            • weedcookie
                              • Oct 2007
                              • 101
                              #44
                              Well here is a story for yall....
                              By an accident was passing by thise shop about an hour away from where i live, seen a sign said: E30 PARTS!
                              Obviously i had to check it out....got a LSD for 100$ :D and drove off with the biggest smile.
                              SWAPED IT yesterday, in a garage not outside.....and it was a fukin bitch and a half. Those nuts are so efin hard to take offf i was about to snap. Pretty much it toook 4.5 hours and 6 beers!
                              But at least i got some decent traction now whoooooooooooooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
                              :hitler:
