e82 power M-Sport seats into e30 - perfect size, not too hard
  • irish44j
    • 2763
    Not that I'm the first to do this, I'm sure, but figured I'd document it for anyone who's looking to do a swap using e82 seats, since I picked some up in "like new" shape locally for less than the cost of recovering my very rickety and crappy e30 Sport seats. I'm not sure exactly how they compare in shape, size, and mounting points to the more commonly-done e46 and e90 seats, but here's the deal
    Bottom Line Up Front, in case you don't want to read the whole thing:
    - In terms of overall size, they're almost exactly the same as e30 Sport seats
    - require making new mounts for 3 out of the 4 bolts (no, the front two do NOT drop-in fit like they supposedly do for e90 seats)
    - They're CANBUS, but I found an easy, if not perfect, workaround to make all the electrics work (except, possibly, the memory function)
    - If mounted the way I did them, they sit plenty low enough for me (6' tall) to wear a helmet in an e30 w/ sunroof
    - They are pretty damn nice. Comfortable, awesome bolstering with the adjustable bolsters, and tons of adjustments
    - They don't wobble, wiggle, rattle, or really move at all, even when physically trying to make them do so
    - Looks are subjective of course, but I think they look pretty good in an e30, aside from the modern-looking tilt mechanism up on the shoulder
    - e30 seatbelt receiver more or less bolts on. Seat clears the seatbelt "rail" near the sill on early e30s.
    Ok, so if you read that and want to see the rest, here's the full writeup:
    Got these seats. I have an e30 coupe, so made sure they're from an e82 COUPE so I can keep the tilt-forward. For anyone wondering, I paid $400 for the pair which is way cheaper than rebuilding/recovering my e30 seats (and way less work). So after eyeballing them on FB marketplace, went and got them with hopes they'd fit and I could figure out how to make the electrics work.
    These are the M-Sport seats, btw. The non-sport seats are flatter and less bolstered
    Lots of motors and electrics. They're not light....but this isn't a racecar, so I don't care. I have an e30 racecar for going fast :)
    This is the plug pinout, for your reference
    Basically, you're going to use the two brown ground wires (attach them to chassis ground). You're going to use the two red (red/brn and red/blk) power wires (attach to power, switched or constant, whatever you want, and preferably fused). And you're going to use the tiny orange/green wire (more on that later), which is the CANBUS high wire. The green wire is CANBUS low, which you can hook to ground but I don't think you actually need to.
    If you have the chassis-side connector from the donor car, you can use that. I didn't so I just chopped the plug and directly spliced the wires I needed.
    Now, here's the thing:
    - When you first power it up, everything works fine. But exactly 10 seconds after you stop messing with the controls, the seat goes dead (except the upper bolster pump, which apparently is independent of the CANBUS for some reason, so it will keep working). It goes dead because the CANBUS module in the seat isn't getting a signal from the car's CANBUS (since the e30 doesn't have it). So, it goes "to sleep." so to say.
    - To get it to "wake up, " you need to provide a pulsed signal to the CANBUS high (orange/grn). Now, electronics guys get a signal generator. Others say a solid 5v power will keep it awake (I tried that, and it does NOT work on these seats). But the thing is, it doens't need a real CANBUS signal. Just a pulse of any kind. So you can just connect-disconnect-connect the power to the CANBUS high wire and it'll wake up. I temporaily put a rocker switch in line so I can just flip it twice and wake the seat (for 10 seconds, then you have to do it again).
    - Future plan: use an inline strobe light module ($6 on Amazon) as my "fake" CANBUS signal. It will work, I'm quite sure of it.
    So, that's the wiring, basically. You can figure out where you want to get the power from, etc.
    Now, mounting it in an e30. As noted, the front two holes don't line up like they do in the e90. The e82 seat rails are about 1/2" narrower. After test fitting, I decided to use the outside front OEM bolt as my reference. So that one stays, the other three get changed. SO I cut the bolts off flush with the floor and drilled a hold in the inside front bolt about 1/2" inside the original one. Then cut off my own bolt into a stud, put it in the hole, and welded it in place through the thicker frame metal underneath. For the rears, you have to move the outside rear bolt directly back 2", which is easy since you can just go through the floor (just don't drill through your fuel/brake lines). The inside rear is the tough one. You have to go back 2" and in 1/2" or so....but there's nothing there, so you have to build a plate with a stud, or some other kind of structure to hold that bolt. I chose to just weld a shaved stud to the side of the slope there, held in place with magnets while I measured. Basically, it's holding in shear for weight and should be plenty strong. Then I welded a washer at the "floor level" to triangulate it with the old floor. Not that complicated if you can do some basic welding, really.
    This was before I cleaned it up and reinforced it more, but forgot to take a pic...this is the inside rear. You can see where I cut off the original stud, to the left.
    Long story short, it fits great. Just like an e30 seat space-wise, but way better.
    clerance to the seatbelt rail
    So, hope that will be helpful to someone out there.
    PS, feel free to follow my rally effort at Pitchblack Motorsports/Rally on Facebook or Insta!
    Stage rally/rallycross e30 build/competition journal
    Track/street e21 build
    visit Condor Speed Shop
    visit Motorsport Hardware
    [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
  • irish44j
    • 2763
    oh, and one other thing. These seats have airbags. So the first thing you should do is disconnect the plug for those (it's the two-prong plug on the outside of the original main plug assemble), and dummy them off with some electrical tape or something. You do NOT want to accidentally put power to them! The rest of the wires are for the seatbelt retractor assembly on the inside of the seat, which you can just unbolt (and use the bolt to reattach the e30 receptacle). And there may be seat heater wires as well. I *think* this seat has a heater, so I may eventually try to figure out how to make it work (pretty sure it needs a pulsed switch, but not sure if it's actually part of the CANBUS or not. TBD.
    • lukeADE335i
      • Apr 2013
      • 1389
      Great work - I came to the same conclusion on my seat hunt and have also got e82 sport seats for my project e30. Haven't finished adapting them yet, but I managed to get fully manual seats so they're not much heavier than e30 sport seats.
      The back seat is actually doable too - width is basically spot on, the backrest needs to be modded to fit. I'm halfway through adapting that (using my sedan here as a test mule for easy access to the seat):
      My e30: OEM+ with M30B35
      • irish44j
        • 2763
        NIce. Hmm, the guy I got these from still had the rears sitting in his shed.......
        Manual seats are generally my preference, but take what I can find for cheap! Weight isn't *too* bad, but not really a concern for me - my other e30 weighs a good 500lbs more than this one lol.
        • 82eye
          • Jan 2009
          • 2106
          nice. i've got a set of e30 sports that i want redone, but this is definitely doable if you wanna go modern look. like the look piles more than the wing back boy racer seats in everything.
          • irish44j
            • 2763
            This one is for the street, so street seats are preferable.
            My other e30 has the boy racer seats covered lol
            • irish44j
              • 2763
              incidentally, here's a pic of the e82 seat next to an e30 sport seat, just for size comparison
              • lukeADE335i
                • Apr 2013
                • 1389
                That's my approach too - I picked up the full e82 interior with only 50k miles on it (it looks basically brand new) for only $550. Much cheaper than sourcing a reupholstered set of sport seats.
                If you compare them with vert or M3 seats with the horizontal stitching they look very similar:
                • bangn
                  • Sep 2011
                  • 760
                  def easier to put in late model E30s that have holes in the floor instead of studs, the factory studs aren't long enough plus nuts get in the way of the seat sliding
                  not sure if E82 have a different floor pattern than E9x chassis but the E9x is also just slightly out, instead of welding stuff to the floor you can just loosen the rear height pivot nuts and spread the rear legs, bolt it down and then tighten it all back up. Doesn't bind and everything works as it should.
                  I have E90 sport seats in mine and the E90 comfort seats I pulled out will be going in the 323i, I love these seats they're perfect for the E30. In terms of wiring on E9x on non-memory seats you only need to use the big B+ and earth supply wires for the switch pack input in the seat side trim, just need to pluck it out of the connector and throw the other stuff away and tie off the airbag cable. I literally have a 2pin connector on each seat, powers up/down/tilt and bolsters. I'm surprised the E8x seats are that complex, guess its to do with that stupid module under the seat.
                  Boris - 89 E30 325i
                  84- E30 323i
                  • irish44j
                    • 2763
                    I was able to use the one factory stud that I kept - it was long enough and the nuts clear the rail on this seat.
                    I didn't think about adjusting the height pivot nuts, hmm. In any case you still need to extend the rear bolts 2"
                    Yeah I'm guessing the non-memory e9x seats must not be CANBUS, probably just a standard controller. Definitely an easier solution. I was actually looking for e90 seats (not finding any at a good price) when I found these so figured what the hell.
                    • 4tDX
                      • Jul 2014
                      • 509
                      How does the height compare to the e30 sport seats?
                      At one point I tried a pair of E36 sport seats, but they sat too high - higher than e30 seats.
                      • irish44j
                        • 2763
                        Sitting on the ground next to each other, the seat cushion is at the same height off the floor for both seats. HOWEVER, the main difference is that the e30 sport seats definitely have a softer/less firm cushion so you sink down further "into" them while the e82 cushion is definitely firmer and you don't sink down as much, so you do sit a bit higher. I would guess maybe an inch or a bit more? IDK, hard to say exactly. That said, mounting DIRECTLY to the floor like I did (vs. using a bracket that lifts it an inch or so like guys do for the e90), allows it to be pretty close to e30. I'm 6' tall and this is a sunroof car, and my Stilo helmet has a very large shell compared to most helmets (it's a rally helmet). Sitting in a normal "performance" seating position I can still fit my hand between the helmet and the headliner. More clearance if you tilt the seat further back, of course.
                        Obviously, everyone is built differently, but I personally like the seating position and there's plenty of space for me. If you're 6'4, maybe not :)
                        Here's a photo
                        • irish44j
                          • 2763
                          here's what both look like installed with the OEM center console, if anyone cares.
                          • efficient
                            • Feb 2012
                            • 3312
                            Darn that looks good. Wish this would have came out sooner cus I redid my sport seats but still haven't done the rear carton part.
                            • Northern
                              I like cupcakes & sh!tboxes
                              • 5284
                              I have a set of these in my basement from an earlier 135i which I guess is why it is missing a stitch up the middle of every bolster.
                              Black leatherette/manual/I think heated, but the driver seat base is ripped at the seam so they need to be recovered.
                              LSeat said they'd give 50% off to anyone who sends their leather in as a template... I'd basically break even with shipping that way, so if anyone in the US does this, let me know so I can put an order in...
                              Originally posted by priapism
                              Originally posted by shameson
