MauR's E30 - Track Car & "Daily"
  • MauR_95
    • Aug 2024
    • 47
    Hi all. I continued...
    After 3 years in Germany. I decided to return to my home country, Spain.
    We started the trip with my two cars (E30 and E87) (together with a friend).​
    • MauR_95
      • Aug 2024
      • 47
      Random photos:
      Click image for larger version  Name:	6C2Coeb.jpg Views:	0 Size:	166.1 KB ID:	10125748
      Click image for larger version  Name:	YxrtEEL.jpg Views:	0 Size:	160.1 KB ID:	10125749
      • 82eye
        • Jan 2009
        • 2033
        that's a pile of first class work. i'd kill for a car so clean. good job.
        • MauR_95
          • Aug 2024
          • 47
          My first trackday with the E30 in Spain. In Calafat, Tarragona (Spain), one month after returning from Germany.
          I had some problems that day.
          • MauR_95
            • Aug 2024
            • 47
            Unfortunately, I did not calculate the wear of the brake pads and could not improve the time set for the first position.
            After the hot day, I ended up taking a walk through the Mediterranean lands of Spain.
            To be continued...
            • MauR_95
              • Aug 2024
              • 47
              Thanks man!! If you like what you've seen so far, you'll love what's coming next.
              • MauR_95
                • Aug 2024
                • 47
                The next day, take advantage of the morning to go on a trip through the mountains.
                The day didn't end very well, a car jumped a stop sign and damaged my front bumper.
                To be continued...
                • MauR_95
                  • Aug 2024
                  • 47
                  Fortunately, the previous accident did not affect the suspension system, it was just visual damage. I continued to enjoy the car until the new parts arrived.
                  Click image for larger version  Name:	Acyi0nc.jpg Views:	0 Size:	153.1 KB ID:	10125769
                  Once the bumper is painted, take the opportunity to apply anti-gravel to the back of the bumper to prevent future rust.
                  Click image for larger version  Name:	1z8DRDC.jpg Views:	0 Size:	154.4 KB ID:	10125772
                  Click image for larger version  Name:	gB5qXOw.jpg Views:	0 Size:	97.3 KB ID:	10125773
                  Finished.
                  Click image for larger version  Name:	CxsF6sa.jpg Views:	0 Size:	190.5 KB ID:	10125774
                  To be continued...
                  • MauR_95
                    • Aug 2024
                    • 47
                    A few months later, I decided it was time to get serious with the car. So I decided to restore the entire underside of the chassis, so grab some popcorn because there is a lot to show.
                    I put the car on the lift to take pictures before starting:​
                    • MauR_95
                      • Aug 2024
                      • 47
                      To be disassembled.
                      • MauR_95
                        • Aug 2024
                        • 47
                        Parts that make my heart ache.
                        • MauR_95
                          • Aug 2024
                          • 47
                          I made some carbon fiber rear covers for the fuel pump.
                          1: 0,28616lb to 0,06261lb
                          2: 0,6045lb
                          to 0,14727lb
                          • MauR_95
                            • Aug 2024
                            • 47
                            Weld the reinforcements to the chassis, wishbones and rear camber kit.
                            • MauR_95
                              • Aug 2024
                              • 47
                              Clean and brush the entire underside of the car. Then apply 3 coats of epoxy and finish with 2 coats of antigravel.
                              Also paint the engine bay in gloss black.
                              Clean fuel tank.
                              • MauR_95
                                • Aug 2024
                                • 47
                                The front part of the engine vahia was damaged due to a blow from one of its previous owners on the lower part.
                                I took the opportunity to reinforce the area and get the maximum space to channel the air to the radiator and that this was not partially covered.​
