This is a boat forum, right?
  • roguetoaster
    Biggus Tippus
    • 7830
    Welcome to Hide Away (at least that's what we'll call the boat for now), my 1984 Pearson 303!
    This was how I first saw it in an ad a friend suggested I look up:
    It (yes, it) was advertised for 12K and listed where the owner lives in Northern VA, instead of where it was in the water in Solomons, MD.
    I arranged a showing, we ended up taking it out for a brief sail, on a weekday afternoon, and I was sold on it as soon as I felt it respond under helm. Fantastic, responsive, and stable, even when aggressively trimmed and heeled. Even though I didn't plan to make an offer right away, the owner Butch, put me on the spot, and I offered 8.5K. We had a brief discussion and we agreed on 9K with him throwing in a 10' Walker Bay dinghy with a sail rig and outboard.
    Turns out, he had owned it since 1995, and he was rather sad to see it go, but his time sailing was coming to a close.
    It was about a week later that we met up, and I paid him. The boat was now mine, and welcome to stay in his slip in Solomons until the end of the year. However, I had recently picked up my very own slip near to home, and I was somewhat anxious to move the boat, but I did promise the seller a last ride, so it ended up being nearly two months before it got moved. In the meantime, I did a little work, spent a lot of time reading, had a few meals aboard, enjoyed the beautiful view from the slip, and cleaned up the cabin. Taking everything out of the boat was a great start, and it was a solid day of cleaning every surface, including taking the cushions home to clean up.
    My girlfriend used it as an office or just as a place to kick back after a run some days. She also suggested a great new name, Zafiro, that might happen since the name needs to be repainted at minimum.
    Our only mod and savior also sent me a sticker, which confused the owner in the neighboring slip.
    Next time, we do a little work to keep water out, head north to a new home, and get all of the documents for the boat.
  • uturn
    • Dec 2010
    • 1006
    Awesome! Congratulations!
    Live that best life!
    • 2mAn
      Señior Mod
      • 20992
      The sticker looks amazing as a boat
      congrats…BTW somewhere I think on Spotify I have a boat playlist I made a while ago… yes, boats&hoes is on it
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • roguetoaster
        Biggus Tippus
        • 7830
        Thanks dudes. It's a shame I passed up on the boat I looked at before this one, since it had a BMW Marine engine, even though that was just a brand exercise from whatever European manufacturer.
        I'm not sure how much of a project this boat will be, since I spent more than I kind of wanted to, but there are definitely things to do on this thing.
        • BlackbirdM3
          • 2772
          One of my crew lives aboard one of these. I've gone sailing with him on it and it sails okay. Not nearly as exciting as sailing my boat, but its much drier, and requires about half the thought when doing a gybe.
          Enjoy.
          '88 BMW M3
          • roguetoaster
            Biggus Tippus
            • 7830
            Enjoy.
            Yes, it's far from a race boat, but it is a lovely coastal cruiser. TBH, I bought it both for the cabin, and for the overall build quality. The other two serious contenders were a J30, which is built poorly, but is fairly quick, and an S2 8.5 which had a significantly worse usable layout with the vang aft, and a wheel conversion. I still do not like the traveler aft of the companionway, and if I find the gear used, a bridge traveler would be on my list of nice to haves.
            If I get to be a better sailor, it will definitely hang with the usual Tartans, Catalinas and other local schooners for summer casual racing. I'm definitely going to clean the hull before the June races, since it was last hauled this June, but was slipped in a fairly slow river, so it's a little dirty already.
            • BlackbirdM3
              • 2772
              Just a heads up, you might want to check and potentially replace the motor mounts as well as the prop shaft coupler. Its a bit of a PITA job to do this, but it can be done, and makes a HUGE difference when these parts new. Kris (My crewmember) did this on his, and it took us a solid half day to get it done. Access is tough, and it often requires two sets of hands.
              These aren't bad boats. They do seem to be solid. You might keep an eye on water intrusion from the cabin windows. We had to reseal Kris's windows last winter. Its a little bit tricky as the glass is actually glass, and it does need to be flexed a little bit to get the frames into place.
              '88 BMW M3
              • roguetoaster
                Biggus Tippus
                • 7830
                If I'm recalling correctly, the coupler has been done, and the shaft was pulled at some point.
                Yes, access in the engine compartment is not the best, especially compared to the S2 I looked at which was phenomenal in terms of engine access.
                It'll be covered in the next post, but I resealed the chain plates, cabin stays, a few stanchions, the forward port lights, which were replacement Beckson units, and only one Bowmar unit. I need to replace the acrylic on the hatches as it's separating from the hatch. Also retaped the mast boot and resealed the base of boot retainer.
                In warmer weather, the entire lifeline system and any other fixture top side is coming off to get resealed. I'll probably use butyl tape for all of that.
                Beyond that, I scrubbed the whole topside and all of the teak before the water at the marina got turned off for the season.
                Probably going to replace the furler line as well.
                Most importantly I want to get out and actually sail it but work keeps getting in the way on all the nice days. By nice I mean around 50°, and with some wind but not anything crazy.
