Strict budget, slow restoration. *Now with moar budget*
Instagram: @DrLeadFoot
Build Thread for the Turbo S52:
http://www.wibimmers.com/board/index...turbo-install/
Running log of the daily E46 M3:
http://www.wibimmers.com/board/index...46-m3-journal/
Flickr
https://www.flickr.com/photos/70254549@N06/
fuck nate your car is coming out pretty nicely :)Originally posted by InuFayesilver is old man color car. you need dat BRO-SECA BLUE.Originally posted by blunttechso true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslistOriginally posted by george gravesAn S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.Comment
how did you wire up your fx-r highs and high beams? I just ordered some fx-r 1st gens , but i have a early so when i hit the highs my lows turn off.Comment
Wire up the solenoids in parallel to your regular high beams, then connect the high beam signal to the relay trigger with a diode--the anode (the striped end) should be on the low beam side of the diode. My wiring is still pretty ghetto-fab so I'm not going to post pictures, but that's the gist.paint sucksComment
so you carry all those tools in the trunk? i just finish reading all 30 pages. nice....Comment
ps , can you PM me a pic? Im not sure what relay your talking about. thanks againComment
Subframe time!
I started by supporting the subframe and removing the main subframe nuts. These are 22s, if you don't have a deep 22 yet, you'll need one for your crank pulley when you do a timing belt, and for steering wheel removal.
Remove the allen key bolts here. The subframe retaining tabs can come out then. (yes I use my frame rails as jackstand points, they're already folded over)
Time to undo the ebrake. I did it from the rear. After you've got the caliper/rotor off you'll need to use some strong needlenose pliers to unclip two springs, one up here
And one down here
You are supposed to use an allen key for these suckers, but I just used pliers. Grab it
Rotate 90 degrees and pull out.
There's one for each shoe.
Grab the shoes and adjuster at the top and don't lose anything. Now you can actually undo the cable. There's a little pin fastening the cable to the actuator. Don't lose it.
Here's what the actuator looks like, normally it's folded together so the pin is retained.
And here's the whole assembly
Remove speed sensors if you plan on retaining your ABS (mine doesn't work but for dexterity's sake..)
Undo the little clips
Unhook swaybars (I need to re-adjust that one, looks like it came loose)
Don't forget the exhaust, chassis-to-trailing arm brake lines, driveshaft, shocks, diff bushing bolt, speed sensor in the diff and whatever else I didn't take pictures of.
It came out with relatively little drama. Lucky me.
Get to work!
I fashioned a little press for the trailing arm bushings. M12 or 7/16" threaded rod, bolts, washers and 1 1/4" pipe and cap to press the bushing out into. You'll have to cut up the end of the bushing a little in order for it to come out with no drama.
My diff was grimy as fuck and my friend left his pressure washer at my house
You can actually see the stamp of approval now, haha
I just drilled some holes in the diff bushing and punched it out with a BFH. Later I'll thread a hack saw through the metal ring and finish getting it out.
Good view of UUC swaybar reinforcements
Shit's dirty yo
And pressing a trailing arm bushing back in. Just use soap and water as a lubricant, works fine.
Oh and here's why I'm going to this trouble
More when I finish up.Last edited by Wh33lhop; 11-14-2011, 12:52 PM.paint sucksComment
