(UPDATED 3/1: More Pics!) My Cheap CL E30 project car!
  • PutterMcGavin
    • 605
    Well I finally got lucky and found a "fair" E30. Called the guy within 10 minutes of it being thrown up on Craigslist and had it bought within and hour. !
    Couple specs:
    - 1989 325i
    - 243,xxx miles
    - 2 door
    - 5 speed
    - Zinnobarrot
    - Tan interior (or at least parts of it, I don't care)
    - Seats I think out of an Acura RSX (they actually look pretty good IMO and whoever installed them did a good job!)
    The good:
    - Seems like a strong engine, idles nicely, revs quickly, doesn't leak any fluid, nothing weird out the tail pipe, clean oil, etc
    - All wheel bearings recently done
    - Towers look good
    - Suspension doesn't "wobble" (did 70 and she tracked straight and true)
    - 95% of electrics work
    - Only a small 2" crack in front of dash!
    It NEEDS (bad):
    - Cooling system overhaul (although I think it is just the TB warmer leaking)
    - UV joint
    - Steering wheel is WAY off center (she drives straight though and turns fine)
    - Radio needs re-wired
    - Back seat is $hit
    - Some suspension components
    - Tires
    Things I'm doing (so far):
    - Intake manifold gakets
    - TB gasket
    - Thermostat
    - Water pump
    - Timing belt
    - Radiator (looks ok though)
    - Plugs and wires (cap and rotor look fairly new)
    - Various hoses
    - Look at suspension and replace if necessary
    - Buff up the body
    - Strip the interior
    - Misc.
    I have some work but none of it (knock on wood) is 'high dollar' and i can do it over time.
    If ANYBODY has suggestions on things I should check or replace let me know! I'm just starting to learn about these cars!
    2 minutes with cleaning wax on left
    After only 10 minutes of buffing! Can't wait to get a PC on it!
  • StereoInstaller1
    GAS
    • 22679
    Wow, hell of a first post!
    Welcome to R3V. Most find this place and these cars highly addictive. Looks like you have found a heck of a deal on that car, too. I would start off by flushing every fluid in the car, but I bet you already planned that.
    That spray bar over the cam is the ONLY lubrication that the lobes get...clean it out carefully!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • 550
      • Nov 2008
      • 107
      That's some major win if I do say so myself!
      • PutterMcGavin
        • 605
        Luke
        I appreciate it! I know this will be an "addicting" project but I knew that coming into it! I own a E39 540i/6 and have done just about everything under the sun to it so I know what addiction is!
        Thanks, I think that too!
        • PutterMcGavin
          • 605
          Couple pics of my other car. '99 540i/6. Full Dinan Stg 5 engine upgrades, eibach sways, ASA wheels with 275's at each corner, Koni FSD's and Eibach springs, M5 LSD, M5 brakes, etc. etc. A ton more to list...
          • StereoInstaller1
            GAS
            • 22679
            E39 was a bit more than $250, huh?
            Sexxxxy car.
            Closing SOON!
            • oekundar
              • Sep 2007
              • 964
              Another e39/e30 cult member...welcome! :D
              BMWCCA #389756
              • oekundar
                • Sep 2007
                • 964
                Btw...if you plan on taking the motor apart, start looking at seals...all of them..but if it doesn't leak...keep it moving. :)
                BMWCCA #389756
                • maximumangle
                  • 497
                  welcome. mega win for $250. more pics of the E39?
                  98 540 MSport
                  89 325 ix
                  • PutterMcGavin
                    • 605
                    Sexxxxy car.
                    A little bit more :twisted:
                    Yes sir. Good to see you in here as well! Remember seeing you in bf.c
                    I'm definitely going to checkout what I can. I don't plan on taking it down any further than it is but replacing all the gaskets I can. I have a TON to do. If something does end up leaking after all this I will just pull and rebuild the whole thing...
                    Thanks. Sure I have a "few more"
                    Since I enjoy whoring, a couple vids
                    Tail of the Dragon run
                    VIR Skidpad
                    • maximumangle
                      • 497
                      diggin the rims. i should have been more specific. pics of engine? :D
                      98 540 MSport
                      89 325 ix
                      • PutterMcGavin
                        • 605
                        REALLY old pic but only one I can find. Recently cleaned the whole engine bay so it looks much better. A little bigger than the M20...
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          Damn you people. This is golf. Not a rock concert.
                          • maximumangle
                            • 497
                            98 540 MSport
                            89 325 ix
                            • T3rd Ferguson
                              • Aug 2005
                              • 3076
                              happy gilmore
                              1989 Bronzit 325ia- Sold
                              1988 Delphin 327i- Sold
                              1995 Cosmos M3- Current
