Well some of you guys may know, I recently had the car painted and will be color sanding (I hope) this weekend, along with getting the air dam back on.
Now I figure I might make a driveline upgrade thread :D
I will be doing a GM ECM swap soon to support the '885 top end I just picked up, and figure why not document it. Timing belt is due, so best thing IMO is to modify the car while it's apart. Will also be doing a permanent install of a WB o2 sensor/display that hopefully will looks stock, might even use one of these extra turbos I have in the garage haha.
Got a machine/fabrication shop, so this should be fun.
Sandblasted and powdercoated the manifold today, forget how many coats. You will have to bear with me, work on a lot of stuff (e30 and Firebird for myself, and countless side jobs).
Here's what I got so far...
New paint...
Don't have pics of the head, but I'm sure you guys know what that looks like
Manifold after powdercoating...
Stock interior...
Stock engine (for now)...
Proposed ECM...
WB display. Probably going to make a mount for it on the dash between the guages and driver's side mirror...
And a similar swap I just completed in a a friend/customer's Camaro...
I will be able to datalog simply by plugging a USB into the laptop and opening a program. Tune will be the same as it would be if I decided to start tuning the '027 Motronic, but I like the idea of being able to datalog rather than tuning blind :D
-John
New paint...
Stock interior...
Proposed ECM...
-John
