Well... she is DONE!!! And the totals are in... GRAND total = $2147.23. Like I said, "semi budget." I knew I was going to spend extra money like the hot coatings and stuff like that to make it a clean and "kit" looking install. I hope I accomplished that.
Though I did get a great deal on the BIG dollar main components, it's the little things that add up very quickly. I still think that dollar/hp ratio is pretty good and if I get 200rwhp out of it I will be 10000000% satisfied. If you were to buy a complete turbo kit with manifold, engine management, turbo, tune, every line/fitting/gauge, etc... it would easily run $4000+ so I think I still made out pretty well. Also sold my reground cams and chip for $200 so that helped offset costs a little.
Here is EVERYTHING that was purchased including tools that I didn't have/couldn't find but needed:
Turbo (Mitsu Starion) w/ Internal Wastegate and Actuator
Manifold
AEM UEGO Wideband Controller
VDO Boost Gauge
Air Intake Temp Sensor
Plug n Play Megasquirt
Oil Feed Line
Oil Pan w/ Turbo Drain Tapped
Silicon Intake Elbow
Valve Cover Gasket
Oil Pan Gasket
Oil Filter
Hot Coating for hot side of turbo, manifold, and downpipe
10" Electric Fan to replace stock AUX fan for AC
Custom A/C low side line to fit around turbo
Custom oil line with T fitting
Refrigerant (frion)
Misc Bolts
Blow off Valve
Intercooler
Intercooler Piping Kit
Rewelding of Turbo Manifold
Custom exhaust (2.5" Downpipe to 3" from back of motor to muffler)
Serial Cable (for Megasquirt)
3 Circuit Harness (for wiring of 10" fan)
Rubber reducers (only 1)
Snap Ring Pliers Set
Downpipe Flange
Oil
Paint
Gasket Scraper
Breather for ICV
Rocker Switch for hardwiring main Efan
Vacuum T's, Splices, and Hosing
Spark Plugs & Gapper
Electric Oil Pressure Gauge
Motor Honey
Magnetic P/U Tool
Manifold
VDO Boost Gauge
Oil Feed Line
Valve Cover Gasket
Oil Pan Gasket
Oil Filter
Refrigerant (frion)
Misc Bolts
Blow off Valve
Intercooler
Downpipe Flange
Oil
Paint
Gasket Scraper
Breather for ICV
Motor Honey
Magnetic P/U Tool
