The DME and gauge temp senders could not have gotten switched because the DME is a two prong and the gauge is a single prong. The wire going to the gauge sender is brownish with a whitish stripe.
Wishno's winter beater project thread(+misc vert action)
so its running now just a pegged temp gauge?Comment
maybe a bad sensor? i cant see how it went bad from motor to motor though...Comment
Swapped temp senders and still the same thing. Unplugging the sensor does the same thing as well so the gauge isint getting a signal from the sensor. Is it possible that I put the wrong connector on it? Are there any other single pin connectors that I could have mixed it up with?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
im throwing out ideas here, are the knock sensors 1 pin wires?
all i can think of nowComment
Sounds like you have the engine wired wrong.Comment
Got the car started yesterday and it idles fine after a few noob things I overlooked in my haste. It turns out I had my oil pressure and temp sender plugs wrong but still the same issue. So the plug that goes to the temp sender has to wires but only one gets used right? Once I get my Z3 temp switch I will install the cooling system and see if that helps. Fingers crossed.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
yes, some plugs have 2 deals but most temp senders are 1 prongComment
Ya it was pretty cool to get all the local guys over. I had 5 E30s in my driveway at one time. Got the shift linkage all together tonight. Turns out im going to need to shim my motor mounts to get the headers to clear the subframe.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
cant you have headers adjusted?
seems like a better optionComment
