Wishno's winter beater project thread(+misc vert action)
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #151
    Less motor buying, more motor swapping ;)
    • Wishno87
      • 6025
      #152
      Took the pan off today. I was pleased to find the pan had more oil remaining than I had expected.
      I also decided to wait on doing the AC on this car until I have it all together and running for a while. I dont want to complicate things from the beginning. If I still have the car by spring I will buy the AC adapter fittings and get it going.
      I was also pleased to find the oil pump did not receive any damage.
      • Wishno87
        • 6025
        #153
        Dont worry Darin this will be the last one I hope. I still have a lot of things to buy for it but I expect to get it running before the end of August.
        • Wishno87
          • 6025
          #154
          The garage
          Pulled out all of the AC stuff and pressure washed the bay again
          Why does this paint always flake off soo badly? Any ideas for new valvecover color?
          • Wishno87
            • 6025
            #155
            I removed the intake and wiring harness tonight. It was such a mess of tires and hoses though that im not looking forward to putting it all back :|
            • Matt-B
              The Waffler
              • 3856
              #156
              looks good inside...
              i called you. and got voicemail. Please call me before 2pm
              • Wishno87
                • 6025
                #157
                Question gentlemen. What are these and does it look like I should replace them?
                • Matt-B
                  The Waffler
                  • 3856
                  #158
                  sensors for coolant inside block maybe?
                  • M42Power
                    • Dec 2009
                    • 519
                    #159
                    Less 24v, more big six
                    Originally posted by kendogg
                    Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
                    OG RACECAR
                    • Wishno87
                      • 6025
                      #160
                      Turns out they are knock sensors. I forgot M50s had those.
                      There wont be any big six action for a long time if ever. I may tear the M30 down a bit to make sure its a good motor but not until the M50 car is done.
                      • Wishno87
                        • 6025
                        #161
                        Pulled off the valve cover tonight. The gasket is the rubberish type so i can just reuse it right? I will probably just pressure wash the oil out of the valve cover for now until I can get my parts cleaner going. The cam looks pretty clean but is there anywhere I should check for wear?
                        • Matt-B
                          The Waffler
                          • 3856
                          #162
                          hmmm maybe it did only have 86k
                          • Wishno87
                            • 6025
                            #163
                            Havent updated in a while. Got my 5sp pedal swap stuff yesterday. It was a bit of a PITA with the harness always in the way but it went better than expected.
                            I got the valve cover cleaned up and repainted. I expected it to be more of a silverish like the rest of the car but it turned out more like a primer gray.
                            I swapped springs between the swap car and the eta. Its weird to see the car like this when it used to be pretty low.
                            For comparison
                            • Dj Buttchug
                              • Jun 2010
                              • 7637
                              #164
                              that valve cover needs more prep before paint. It looks like its all peeling off already.
                              Turbo M42 Build Thread :Here
                              Ig:ryno_pzk
                              I like the tuna here.
                              Originally posted by lambo
                              • Wishno87
                                • 6025
                                #165
                                Its just the casting. It was pressure washed then sandblasted then pressure washed again. I probably could have sanded it smooth or something though.
