Starting from scratch.... '89 325is Build.
  • Sir Young
    • Jan 2010
    • 46
    #106
    You do some good work sir. I'm a biiiit iffy on your rear suede enclosure but I will see the final product to be certain. Everything looks quality however! :D
    535is
    • freeski27
      • Sep 2009
      • 388
      #107
      Wow, longest delay ever... good things come to those who wait :)
      The Engine Swap 1...
      Hey guys,
      Sorry it’s been a while since my last post, but I’ve been really busy with school and whatnot. But we are on to the engine and whatnot now. I ended up picking up a running e30 M50 that had been totaled by insurance. So I’ve got all of the necessary parts at once. So I started with removal from the parts car. I didn’t take too many photos of the removal process because it was just a messy grimy job, but for the most part the idea is, disconnect everything you can find then try to pull it out, disconnect the things you missed and try again. Keep repeating this till the engine is out…
      Here are some photos of the engine removal:
      Well that looked easy! Haha, just take your time and it will all come out. From there I really just started to clean things up as best I could.
      Here are a few shots of cleaning things up:
      Some wire-wheel artwork… Haha
      Now that the engine was stripped down of all accessories and relatively cleaned up I began breaking down components to replace all crank case and valve cover seals.
      Here are some photos of breakdown, paint and cleanup:
      To remove the crank bolt, I put some blocks of wood between the crank and the block to keep it from spinning.
      Then used a really big pipe… haha, I only stood about 6 feet out.
      I used a bearing puller to pull the hub:
      Some touch up:
      Found this when I pulled the timing case…
      Covers were pretty shoddy, so I decided to repaint them flat black:
      New chain guide rail:
      New, metal impeller water pump:
      And now as the engine sits!
      Sorry for the lack of my usual cometary, but I figure the pictures speak for themselves here. If you are going to do this work, I must say, it is soooo helpful to get a manual for the car your engine comes from. I know it sounds trivial to do so, but sometimes it can be hard to drop 40 bucks on a book :/
      -Noble
      E30 325is "Starting from Scratch" build thread
      • freeski27
        • Sep 2009
        • 388
        #108
        Hey! I'm gunna be putting this thing in on sunday if anybody wants to come by!
        • TrentW
          • 2815
          #109
          The engine looks good. What did you use on the bare aluminum parts to get them looking so good?
          • freeski27
            • Sep 2009
            • 388
            #110
            I used a wire wheel first for the really tough areas, be sure not to hit any mating surfaces with the wire wheel though. From there I used "Scotch-Brite" to bring down the scratch. "Scotch-Brite" is what you want to use on the mating surfaces as well because it wont mess it up. From there I used compound to shine it up, I threw a little wax on there (not on the head...) after words to keep the shine.
            • Kershaw
              • 11822
              #111
              looks really good. i gave your entire thread a read through. impressive.
              you never did answer the one guys question on what kind of carpeting you used. im interested in the answer as well.
              AWD > RWD
              • ahriley91
                • Jan 2010
                • 451
                #112
                I would totally come by and help...if I lived in CT...and wasn't putting mine in this weekend too. haha. Good luck with it! I love the thread. Everything looks great.
                http://www.r3vlimited.com/board/showthread.php?t=162444
                • freeski27
                  • Sep 2009
                  • 388
                  #113
                  ah, guessed I missed it!
                  The carpet is actually left over carpet from my boat project. It is marine carpet, but I don't remember the exact type. I have the order for back home though, Ill let you know what type it is after this weekend.
                  • freeski27
                    • Sep 2009
                    • 388
                    #114
                    It's good stuff though, just cause it's marine carpet doesn't mean it is rough or anything like that. I think it is like 24oz, it has a good feel, it's BLACK, and it is water/mildew resistant.
                    • freeski27
                      • Sep 2009
                      • 388
                      #115
                      haha, yeah. Washington is a bit of a haul from here. Good luck with the swap though! Let me know how it goes!
                      • ahriley91
                        • Jan 2010
                        • 451
                        #116
                        Same with you! I'm super stoked to see your final project. I'll be updating my build thread after I'm done puttin it in if you wanted to check it out. haha.
                          • 37829
                          #117
                          Engine looks great now!! Is that DanGillan's old 4 door you got the motor from?
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • freeski27
                            • Sep 2009
                            • 388
                            #118
                            It is indeed! But I actually bought it from the guy who bought it from him... if that makes any sense.
                            • ahriley91
                              • Jan 2010
                              • 451
                              #119
                              Any updates?
                              • rattlsnak
                                • 45
                                #120
                                bump for updates?
