The Blue Lagoon - LS1 Content
  • Blip Bavarian
    • 236
    #31
    Originally posted by Iain
    Great thread - yet another subscriber. I'm in the process of building an LSx (L98) E30 too. :)
    I have Garret and Steve's build CD - how close were your engine mounts to the ones on their plans? Did you go Corvette rubbers or E34?
    I'm looking at doing a remote-mounted booster from a Toyota van under the dashboard, with the master cylinder in the engine bay - kinda like what hot rod guys often do. VH40 and VH44 are the boosters to look at IIRC
    From what I've seen under there you don't need to do much at all to fit a T56 (which is a fuggin' huge gearbox). Garret had to dremel off some of the lugs on the side of the T56 and hammer a couple of small humps out.
    the mounts are very similar to Garret and Steve's. I bought a pair of LSx motor mount plates though. I originally bought the e34 mounts, but we ended up using the GTO mounts that came with the motor instead.
    I will look into those Toyota boosters. sounds like a good idea.
    All it took to clear the tranny was a couple whacks with a hammer, and like Garret and Steve we trimmed a couple of the usless nipples off of the trans housing.
    I am really interested in your build. There are gonna be several LSx E30's in no time. Are you gonna document your progress?
    My LS1 swap thread:
    http://www.r3vlimited.com/board/showthread.php?t=160030
    • Iain
      • Oct 2005
      • 2815
      #32
      Thanks for the info. Where did you get those motor mount plates from? GTO mounts would be great 'cause then i could just use the standard Holden Monaro mounts!
      I have a project thread on here but the progress on my car has been epically slow and 90% of the thread is just verbal diarrhea. Basic rundown is: L98 6.0L (no air con or PS to make room), custom 1 7/8" headers (if I can squeeze them in), big cam, valve springs, bigger injectors, custom clutch, lightweight flywheel, T56, E36 non-PS rack to fit the headers, E36/318ti 5-lug suspension, Holden VE Commodore brakes (+300mm rotors & twin-piston calipers), custom-made re-routed loom (to make space in engine bay & under dash), Nissan R200 diff & driveshafts, and shitloads more. Just got to pay for it and get some time to get in and do the work!
      I'll be watching this thread closely :)
      Pork Hunt Motorsport
      eBay is like the summit racing catalog for today's special Olympics crowd
      • Blip Bavarian
        • 236
        #33
        wow, sounds like its gonna be an awesome build. Do you already have a cam picked out? specs? I look forward to your progress.
        The headers we did are fairly short for clearance issues. I went with 5/8 primaries, but in retrospect I should have gone for 3/4+. Oh well.
        Here is where i got the motor mount plates. These things seem like they were made for a tank.
        http://cgi.ebay.com/ebaymotors/LS1-C...Q5fAccessories
        My LS1 swap thread:
        • Iain
          • Oct 2005
          • 2815
          #34
          Thanks for the link.
          I'm going to go with a Turbo Killer cam (237/242). I want it pretty damn big and lumpy 'cause the car will only get driven on the odd weekend and short distances... and at the track. I'm using the Holden ECU as we can just rewrite it with LS1edit and the guy who is tuning the car for me reckons this cam will absolutely haul in the little E30. Will also set me up nicely for when I (eventually) go ITBs too :D
          • Blip Bavarian
            • 236
            #35
            Cleaned up the motor and tranny this weekend. Its amazing what some Purple Power and a Pressure washer will do.
            Painted my valve covers black
            My valves are looking pretty clean for a 68k motor
            My LS1 swap thread:
            • Blip Bavarian
              • 236
              #36
              Also, I got all my exhaust parts in this week. I cant wait to hear how this thing sounds.
              spun cats with 4" of metalic substrate
              My LS1 swap thread:
              • yberther
                • 1246
                #37
                Nothing like Garrett's exhaust routing:
                Flickr
                Originally posted by Indecline06
                For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
                • aintnothang
                  • 743
                  #38
                  Subscribed. I love lsxs and e30s.
                  • Simon S
                    • Oct 2004
                    • 3758
                    #39
                    goat motor in an e30 > lego porn
                    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                    • Firestorm
                      • 795
                      #40
                      If only this was the case when running a dry sump...
                      Lsx/t56 Swap progress |----------| .0000000005% - Well below poverty line.
                      Getting purists panties in a knot since 2007. ;)
                      E30 count = 6! :shock:
                      • e30guydownunder
                        • Jul 2008
                        • 874
                        #41
                        I had no troubles slotting my G260 back 100mm :D The sump on the bottom of the m42 is another issue though!
                        - Chris
                        Project M42 - 255 @ 19 psi
                        • Vtec?lol
                          • Dec 2009
                          • 3278
                          #42
                          updates....
                          • Blip Bavarian
                            • 236
                            #43
                            Got some work done this weekend.
                            Pulled the subframe and diff to refresh some bushings. I still need to get some trailing arm bushings, and am looking to get some half shafts in better condition than mine...
                            cleaned up and painted my subframe.
                            Hoping to get started on wiring this week.
                            My LS1 swap thread:
                            • evil_twin
                              • Nov 2007
                              • 2965
                              #44
                              ahh what a sick build! everything is going quite well!
                              Paypal: vdang5@gmail.com
                              Delta Auto Care
                              2875-C Towerview Road
                              Herndon, VA
                              703.435.1375
                              My Feedback Thread: Evil_Twin
                              • Blip Bavarian
                                • 236
                                #45
                                spaghetti
                                have quite a bit of room for radiator setup. Hoping everything will clear without using an LS2 waterpump
                                shifter
                                My LS1 swap thread:
