After a year of searching, an Alpineweiß story
    got a killer deal on some used Toyo Ra1 205 50 15 tires
    got them mounted up.
    spacious backseat, I was able to easily fit 6 wheels stacked.
    My first track day.
    in Fontana ca at Auto Club Speedway
    Successful trackday
    I borrowed my friends transponder as he was having issues with his e30, and i was able to get some lap times fastest lap of the day for me was a 2:19
    Project
    Parts for Sale
    Feedback
    YouTube Channel
      replaced my tail lights gaskets
      old vs new
      I had my friend eric spray a spare valve cover i had in wrinkle black as I was not happy with how my valve cover turned out.
      masked it up.
      I used a belt sander at work to get the majority
      then i used a block sander to get the nice even grain finish
      before and after
      Project
      Parts for Sale
      Feedback
      YouTube Channel
        I want that valve cover Alex.
        » PARTS FOR SALE
        » TRANSACTION FEEDBACK
          Ill give you a call
          Project
          Parts for Sale
          Feedback
          YouTube Channel
            newest additions
            Gregs M rebuilt afm
            a spare lower airbox with the cheese hole mod
            oil change with the larger oil filter
            last piece of sound deadening in the entire car.
            gone!
            1.5 lbs every thing counts
            Cool trick to clean the residue
            Project
            Parts for Sale
            Feedback
            YouTube Channel
              update
              I replaced the fuel filter
              all rubber hoses in the area.
              all new hose clamps
              also a new filler neck hose.
              and some new sparkplugs
              top hose clamp is easy to get to the one on the filler neck near the subframe was cramped
              old vs new
              Project
              Parts for Sale
              Feedback
              YouTube Channel
                Did you go from a smaller oil filter to a larger one? If so i would change it back.
                Too large of an filter and the engine takes more time to build up pressure when its started, thus you get more wear on your internals.
                I used to work at a ford dealership and some of the engines were starting to show premature failures on bearings and such, ford responded by sending smaller oil filters because the problem was that they did not get enough pressure on start up.
                  thank you i will keep this in mind, and go to the stock size filter.
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                    I got an extra set of calipers and I stripped them down.
                    Cleaned them in an ultra sonic bath of simple green and water at 50 Celsius.
                    All cleaned up on the wire wheel.
                    Ready for a bath.
                    All the parts cleaned then prepped with carb spray for a final wipe down.
                    Then sprayed with duplicolor black caliper paint.
                    I saved the old rubber brake lines to use it to mask the hole on each caliper.
                    Bolts fitted into the brake calipers brackets to mask the threads.
                    Paint all dry ready to assemble with new seals
                    Here is a tip for rebuilding the front girling calipers,
                    Place the new seal on the end of the piston and then get the seal to fit in the groove of the caliper then slide the piston in.
                    On the pelican parts DIY and the e30tech DIY it does not cover this step.
                    New front calipers
                    New rear calipers upgraded with brass guide bushings. From Ireland engineering
                    Project
                    Parts for Sale
                    Feedback
                    YouTube Channel
                      quick video of my e30 at the last autocross
                      Project
                      Parts for Sale
                      Feedback
                      YouTube Channel
                        I just read all 33 pages, 3 hours. You Sir deserve a pat on the back, Great job on this car.
                          Thanks for reading. Because of this post I will stop slacking and post some updates. Lately I felt like no one was reading and commenting to I kinda stop posting.
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                            NICE RUN!! can't wait to do so!
                            E30 now S52
                            2008 Suburban LTZ (Family and TT hauler)
                            325xiT (Sold)
                              Thanks.
                              Project
                              Parts for Sale
                              Feedback
                              YouTube Channel
                                Awesome video Alex! I take it that PCA event was at el toro? How did you like the way the event was run? I'm hoping to get back to it in the coming months.
                                Oh yeah, your rev-limiter works nicely :)
