1991 318is Restoration Project...Now with some Air!
  • Stapes
    • Feb 2015
    • 117
    #166
    Hey Tuee, I just read your thread today and, oh boy! What a great job you have done. Truly motivating!
    • Tuee
      • 131
      #167
      Thanks guys! The old bushing is finally out.
      New poly ones put in,
      Finished painting the fronts,
      New brake line and joint,
      And this happened,
      You can probably see where this is going.
      • Hooffenstein HD
        • Nov 2012
        • 1388
        #168
        Maybe I'm just tripping balls but those look like they're upside down.
        • Tuee
          • 131
          #169
          I checked online and it appears to be correct the way I have it...can someone confirm this? Thanks.
          • Dj Buttchug
            • Jun 2010
            • 7688
            #170
            you have your fuel lines backwards??
            also whats circled in red is a knock sensor? m42s didn't have knock sensors.... anyone else chime in
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • MF DOOM
              • Apr 2012
              • 944
              #171
              I think e36 m42s had knock sensors.. maybe?
              EDIT: Yeah, e36 had em. http://www.turnermotorsport.com/p-20...42-engine.aspx
              • pandaboo911
                • 2070
                #172
                The bushings are correct, but I had to cut mine slightly to gain clearance for the trailing arm bolt.
                The "cap" of the bushing should be on top. Also I believe you need to use the original washer that was on top of the bushing.
                Are they powerflex?
                • Tuee
                  • 131
                  #173
                  The block on this car is from an E36...hence the sensor.
                  Are they powerflex?
                  Thanks. Yes they are powerflex.
                  • spanish pants
                    • 294
                    #174
                    this
                    My new E34 525i Sport Limousine Blog
                    http://bmw525isportlimousine.blogspot.com.es/
                    • Ygtbsm1969
                      • Jul 2015
                      • 31
                      #175
                      Commitment
                      Very good build I could read this a dozen times and see something new every time. The question I have is when your done what is the next project you will never be able to stop this is not a project its a way of life and when the bug bites it never stops. Maybe a plane build next?
                      • wark
                        • Jul 2013
                        • 321
                        #176
                        Looks great.
                        Dustin Wark | Instagram ・tumblr・Flickr
                        • Tuee
                          • 131
                          #177
                          Originally posted by spanish pants
                          this
                          Originally posted by wark
                          Looks great.
                          Thanks!In terms of a next project? We'll have to wait on that. Maybe something newer to start as a base, perhaps a newer tribute car to the old, maybe an M? Only time will tell. ;)
                          Well it's been a very slow progress but none the less things are somewhat moving along.
                          Other toys that have taken some time out.
                          This one is gone now, sold it to buy the next toy.
                          So nice to work with new hardware
                          Finally in
                          Had to throw in the old shocks as the Koni's use a 12mm shaft vs the stock 10mm. Didn't realize this when ordering there.
                          Refinished a set of these with new hardware.
                          :D
                          Fronts got put in last weekend. Hope to have it on the ground before winter.
                          • Tuee
                            • 131
                            #178
                            So it's been a while since the last update, but work has been progressing on the car.
                            There was a little delay as the Koni's had a 12mm shaft vs the stock 10mm shaft. So had to reorder the shock mounts. Went with these.
                            Old vs New
                            All in,
                            Next was the exhaust, the old setup was a Frankenstein of random pipes and poorly welded components. First up was the manifold, so nice for a brand new part
                            Time for a new battery,
                            Finally moved out on its own power...wheels will be a surprise.
                            Started to prep the IS skirts, brand new from ECS,
                            • Tuee
                              • 131
                              #179
                              A few more,
                              • Codym42
                                • Mar 2013
                                • 611
                                #180
                                Can't wait to see the wheels. I've been following this thread since the beginning. It's nice to see its still going.
                                Is that a yellow Protege MP3 in the background? lol
                                '90 325i - 5 speed coupe
                                '05 330ci 6MT ZHP
