Reap3rs E30 Bought back, Now M52B28
  • MR E30 325is
    • Dec 2008
    • 3300
    #91
    Originally posted by Danny
    How'd you go about doing that? < --- Sincere curiosity.
    Thats how the AA kit comes, and its really close in the already tight E30.
    I had to cut the radiator support slightly in the bottom corners to get it to fit. The outlet runs across the front of the oil pan, with about an inch to spare. It wasnt that difficult at all.
    *Sorry for the thread hijack, back to reapers build!
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
    • Danny
      • 14216
      #92
      Yeah I actually looked it up on your build thread, well done!
      • Iain
        • Oct 2005
        • 2815
        #93
        Originally posted by Reap3r
        The only way for me to do it on mine is if i run the hot pipe across the front of the engine and then around past the headlight. If I could fit a setup running both inlet and outlet on the same side I'll definently be looking into it.
        ebay - there are plenty. You wouldn't need a big core, either. I reckon nothing bigger than a 500x250x76
        Radiator black paint will be your friend with regard to keeping it stealth, too. Works a lot better than Bunnings flat black.
        Pork Hunt Motorsport
        eBay is like the summit racing catalog for today's special Olympics crowd
        • Reap3r
          • 596
          #94
          Yeah i was thinking more a 300x280 core. I'm not running rediculious boost and superchargers give off a lot less heat than a turbo. Painting the cooler black was the first thing I was going to be doing aswell :P With any luck the piping will turn up this week and i'll mock that up as to where I want it to go and buy a cooler from there regarding if its inlet/outlet both sides or just 1 side.
          Turbo M42 Build thread:
          http://www.r3vlimited.com/board/showthread.php?t=169672
          • Iain
            • Oct 2005
            • 2815
            #95
            I reckon 2" piping will be plenty (overkill, even) and there are some good sized cores around 450x220x50mm large.
            • Reap3r
              • 596
              #96
              I ended up ordering 2.5inch piping. People were telling me to go 3 inch. But the blower inlet and outlet is 2.5inch as is the stock m42 inlet so 2.5 seemed the way to go for it, at least i don't have to mess around with reducers and the like.
              • Ray Smoodiver
                • Jun 2004
                • 8809
                #97
                Looking good, throw up some more pics!
                • Iain
                  • Oct 2005
                  • 2815
                  #98
                  3" would be stupidly oversized.
                  2.5 shouldn't be too bad, though.
                  Good luck with it! What injectors? What ECU?
                  • Reap3r
                    • 596
                    #99
                    Injectors i'm still deciding on. Looking for some 30lbs/hr ones but having difficulty finding the part number for ones that will fit. Alternatively I may just get some 30lb/hr ones from vac motorsport. ECU I was going to go haltech by my mate that was going to fit it ect doesn't have time so at the moment megasquirt seems the way I'll be going.
                    • Blip Bavarian
                      • 236
                      #100
                      Diggin the meats. what size are they?
                      My LS1 swap thread:
                      http://www.r3vlimited.com/board/showthread.php?t=160030
                      • Reap3r
                        • 596
                        #101
                        225/50r16 rear 205/55r16 front. But being semi's they're a lot wider than standard tyres.
                        • Reap3r
                          • 596
                          #102
                          So I got a little package in the mail yesterday and decided to have a little bit of a play around with it all today.
                          The first thing I found out is that I wont be fitting my intercooler where I wanted it to go so I started to mock up the piping where I'm going to run it.
                          I also removed my AC and front fan to allow for more room.
                          While I've got the front valance off I'm going to get it painted along with my iS lip and boot lid that I never got around to finishing.
                          I've basically got a piping set up that I'm starting to be happy with placement and I ordered a intercooler today along with a few more silicon hoses to finnish it all off.
                          As you can see by the time I get a pod filter and a inlet pipe in here for the supercharger this corner is going to be quite cosy. I'll be looking into relocating my power steering resovoir tomorrow and making some brackets to hold all the piping on.
                          • e30guydownunder
                            • Jul 2008
                            • 874
                            #103
                            looks like it might just work man. Keep at it, you will be boosted before my bimmer :)
                            - Chris
                            Project M42 - 255 @ 19 psi
                            • Reap3r
                              • 596
                              #104
                              Latest Update.
                              Unfortunately its all gone back together and the supercharger and all its parts have gone into the corner for the next little while. Had a problem with my daily and needed the bmw back on the road ASAP. So for now I'll be waiting to get a few grand back in the pocket before finnishing off the supercharger swap. Hopefully in a month or 2 I'll be back into it :)
                              • e30guydownunder
                                • Jul 2008
                                • 874
                                #105
                                whaaaaaaaaaaaaaaaa
                                - Chris
