The MR E30 Project Thread
  • benyen soljax
    • Mar 2012
    • 290
    #451
    The steering wheel wiggles without the car being on the ground?
    Project 325is
    Transaction Feedback
    • MR E30 325is
      • Dec 2008
      • 3300
      #452
      The steering wheel will viciously go back and forth with the front wheels on the ground, or with them in the air.
      My previous build (currently E30-less)
      http://www.r3vlimited.com/board/showthread.php?t=170390
      A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
      • benyen soljax
        • Mar 2012
        • 290
        #453
        That would have to be your fluid system then because it eliminates the wheels from the equation. The shitty part is it is not easy to test those components individually...my money is still on that pump lol.
        Project 325is
        • MR E30 325is
          • Dec 2008
          • 3300
          #454
          Problem was temporarily solved.
          Power steering is gone for now.
          Brakes arent bleeding at all. Pedal goes to the flooron the first push, and it will maintain pressure if you pump it twice in rapid succession.
          Even a one second break will cause it to go all the way down to the floor. Even driving it around my neighborhood is a pain in the ass.
          I really dont want to buy more new parts, but if people think the MC is bad I guess I gotta do what I gotta do.
          • pandaboo911
            • 2070
            #455
            steering shake could be a belt slipping if there's oil on it
            not enough fluid in the system?
            • benyen soljax
              • Mar 2012
              • 290
              #456
              That'll fix the power steering too...lol
              As for the brakes, I just replaced the front brake lines tonight and pulled the MC off to replace the seals. Usually if there is a major loss in pressure like that either one of your brake hoses has a major leak, one of the 3 gaskets on the MC itself has given out, or the MC internals are bad. I hope its one of the first two because they are cheap and easy.
              Project 325is
              • benyen soljax
                • Mar 2012
                • 290
                #457
                Can't believe I didn't think of the belt thing.
                Project 325is
                • MR E30 325is
                  • Dec 2008
                  • 3300
                  #458
                  I cant see any leaks, and the brakes will hold pressure very well if i hold the pedal down after pumping it three times in rapid succession.
                  I am going to try the tracing the lines and see if I have a blockage option.
                  Front squirt out fluid very well. Rears barely drain out. Thats my issue.
                  • MR E30 325is
                    • Dec 2008
                    • 3300
                    #459
                    All issues were solved.
                    First drive into town today to grab lunch with a fellow E30 enthusiast.
                    Everything went just fine. I missed speed a lot.
                    • benyen soljax
                      • Mar 2012
                      • 290
                      #460
                      What was it?
                      Project 325is
                      • MR E30 325is
                        • Dec 2008
                        • 3300
                        #461
                        The bleeder screws were clogged, letting almost no brake fluid out. I could have fixed it by bleeding the brakes forever, but I decided to pull the rear calipers off, rebuild them, and soak the bleeder screws in acetone.
                        10 minutes later I pulled them out, cleaned em out with a tiny allen key, reinstalled everything, and the brakes bled much quicker.
                        I drove it to work the past couple of nights, and aside from a few small issues, everything is awesome.
                        Its going back in the garage tomorrow to get the interior put back together, and those few minor issues taken care of.
                        • e30shmobberr
                          • 1934
                          #462
                          love your car man! love your style that you put into the car too!
                          Patrick - IG:niicknac
                          RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
                          • MR E30 325is
                            • Dec 2008
                            • 3300
                            #463
                            Much appreciated!
                            • MR E30 325is
                              • Dec 2008
                              • 3300
                              #464
                              March 24th, 2013
                              Alright, I have a new issue. I bled the brakes, parked the car, got in the next day and the pedal was very soft again.
                              Rebled them, but they arent making the pedal harder. I am doing it right, with the tube/bottle and a second person.
                              Is my master cylinder shot? no more bubbles are coming out, just fluid.
                              The brakes still stop the car, but the pedal is wayyy too soft.
                              TIA
                              • Link
                                • May 2012
                                • 834
                                #465
                                I have the same problem, I am curious what you find out to solve this issue. Good luck.
                                View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
