Little update:
Its spring break for me now so I'll try to get everything that
I can get done with no money done this week. My leg is
healed now so I'm back to work and should have a good regular
cash flow again so that will help.
Also Its the RedBull Crashed Ice this week-end in Québec city...
I will miss most of it though.
So I dissembled my calipers and decided that I'm getting them powder
coated black, SS pistons for the front and solid brass guides on all of
them.
Then I removed the booster in preparation for the booster delete kit that
Lee (Massive) designed.
When I removed the hoses between the booster and the TB, I found one
of my vacuum leaks source, I just pulled them out.
This is how my setup looked like after my ABS delete I did early last fall.
Those of us who have already removed/swapped a booster know that
getting the 4 nuts out can be a pain. But today I went really well.
Since I'm installing the Massive booster delete bracket, the brake pedal
needed to come out sooner or later so I started by this. The brake pedal
and the clutch pedal are on the same axle/bolt but its possible to slide the
bolt only half way out and take the brake pedal out without taking the
clutch one out.
Caution: If you are not careful you can damage the wiring with the head
of the bolt when you slide it out. I also broke my brake light
switch wiggling out the pedal...
Then when the pedal is out and the knee panel as well reaching the four
nuts is very easy with a deep 13mm socket+extensions+swivel+ratchet.
Getting the booster out of its spot ended up being some kind of puzzle but
I got it out eventually.
I also removed the insulation that was behind the booster
and the fuse box. I had the impression that I was removing play dough.
I did find a small rust hole behind the fuse box that was hiding behind
the insulation. One more thing to fix....
Trying to figure out the cleanest way to reroute the brake lines. I will be
neat when done
Charley
them.
clutch one out.
neat when done
Charley
It was a quick fix...
