E30-LS1 Swap KITS now available!!
    Oh shit. Hmmm, wish I had some spare change for this right now.
    Just start collecting parts and tucking them away.........
    www.gutenparts.com
      That's what I planned on doing. ;)
      Matt
      Matt
      I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
      Originally posted by kronus
      try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
      This is like a reverse build thread; it starts out nice and gets shitty.
        im very impressed with the drawings. Looks great!
          I would die to do an LS1 swap...
          Just need moolah!
          1989 BMW 325i SOLD
          1998 BMW Estoril Blue e36 M3/4/5 SOLD
          1987 BMW 325 (The Piece) SOLD
          1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
            Originally posted by James Crivellone View Post
            Garret,
            If you ever plan on doing just the booster linkage let me know, may be a nice addition to my S38 Project.
            I already have a 540i remote booster, setup, but I like how much more compact yours is.
            We absolutely can just do individual parts if you guys are interested. The booster linkage and second diff mount come to mind as stuff that is useful to more than just LSX guys.
            Originally posted by Ray Smoodiver View Post
            Some incredible stuff!
            Any idea on how comparable size wise an S62 is compared to an LSx - would the booster setup be okay to use, space wise for an S62 swap?
            Pretty certain the S62 is wider across the heads, it's a pretty huge engine. As far as booster setup is concerned, it's pretty much is flush with the framerail on the drivers side.
            Originally posted by reelizmpro View Post
            Damn, that's awesome work guys. What's the total estimated cost of an LS swap including engine anyway? sounds like it could be way more bang for your buck over the ever popular S50 swap.
            Our engine, transmission, driveshaft, wiring harness, fuel pump was $4000 and had 45,000 miles on it. We're selling our kit if you plan on going that route for 1200 (engine mounts, tranny mount, booster system, second diff mount, swap guide CD which is a 200 page PDF of every step and part we used). As far as the rest of what you need, there's just the GTO oil pan, exhaust, radiator, radiator fan, etc. Just miscellaneous parts. I'd say you could definitely do the whole swap for $6500....and stock hp output of these engines is 350+ with essentially no weight gain (we gained 60lbs at the end of the day but that weight is more centered due to the beefier 6 speed transmission).
            Cheers
            -Garret
            E30-LS1 aka. 357is
            email us to pick up our LS1 swap guide
            E30-LS1 KITS now available!!
            E30LS1@gmail.com
            e30ls1.com
              The first kit v2.0 is complete! Here are some rudimentary pics.
              KIT - Engine Mounts, Transmission Mount, Radiator Mounts, Booster Linkage System, Second Differential Mount (note: Swap CD included also as well as hardware - Nuts, Bolts, Differential Mount plates not shown)
              Engine Mounts
              Transmission Mount v2.0 (modified to make more room for exhaust clearance) pre-paint
              post paint
              Booster Linkage System (hydroboost shown is for demonstration only)
              Second Differential Mount - in our car
              About to drill holes to mount plates for Diff Mount
              Radiator Mounting Bracket
              Cheers
              -Garret
              E30-LS1 aka. 357is
              E30LS1@gmail.com
              e30ls1.com
                DĂĽ want. :crazy:
                Matt
                Matt
                  I have always been interested in this setup... but the one thing that turns me off is the trans. A long long while ago I drove the last z28 model chevy ever made, and i just felt that the trans felt too cheap to me. Can you maybe dispel those feelings for me by comparing it to the m20 trans feel?
                  E30 Dinan Turbo
                    that is some hot shit. good work.
                    past:
                    1989 325is (learner shitbox)
                    1986 325e (turbo dorito)
                    1991 318ic (5-lug ITB)
                    1985 323i baur
                    current:
                      What made you guys go with a remote hydroboost?
                      I went with a mark I jetta booster and just drilled the firewall and petal assembly to slide it over an inch and a half.
                      But to me everything looks great guys keep up the good work.
                        Get an aftermarket shifter. Problem solved.
                        Matt
                        Matt
                          Seeing how much development cost is for engineering that is a steal! Would you be including the drive shaft as well? I wonder what size tires you would need to have all that power be useful!
                          Adam
                            Hey guys, quick update. Our kit does not include the driveshaft because they are usually included in your engine/transmission/driveshaft that you need to get. It's really easy to take them to a driveshaft shop and get them shortened. I think ours was less than $100 to get shortened and balanced. We're currently running 205 tires with a 2.92 diff and it spins the tires under power in first and second but still hooks up pretty well. You still can in third but you have to actively try to. Again, that's with a 2.92 diff though. A 3.44 or higher and you would surely get more tire spinning fun.
                            Here's a pic of the v2.0 trans mount installed in our car. We made it for easier exhaust running and we think it looks a lot better too.
                            E30-LS1 aka. 357is
                            E30LS1@gmail.com
                            e30ls1.com
                              That looks awesome guys.
                              WEll done.
                              www.gutenparts.com
                                solid looking kit, only thing I'd say if i were to criticize is to clean up your welds...Tig or adjust the gas on your MIG
