Absorbantnut's '87 325is
  • trackjunkie21
    • Jan 2010
    • 3962
    #76
    Damn, you're doing work!
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • AbsorbantNut
      Non faccio funzionare questa merda
      • Jun 2010
      • 2491
      #77
      Well, painted the valance. Might put up a pic of that tomorrow, but it was very dark by the time I finished, and couldn't really see how it turned out:drink:
      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      • Plastic Emperor
        • 34
        #78
        Great thread, its awesome to see you bring it back
        • frickendom
          • 382
          #79
          What kind of compressor are you using? And where did you get ur paint?
          • AbsorbantNut
            • Jun 2010
            • 2491
            #80
            Well, heres some pics of the valance. It came out great! just need to sand and do another coar on the bottom ruberized half. The top came out near perfect:D
            Heres a few of it on the car
            And this is how the motor is currently sitting.
            And my next victim:woowoo:
            • drutt23
              • Feb 2011
              • 392
              #81
              Sweet progress man! It's lookin good! Keep it up :up:
              1989 325i|1992 325i|And completely obsessed|:woowoo:
              sigpic BMW. The Ultimate Driving Machine.
              The Build...
              • AbsorbantNut
                • Jun 2010
                • 2491
                #82
                Well, did some more work on the car. A few days ago I got the volvo lip mounted up. I just reused the stock lip clips and some zip ties.
                Then, today after school I got the driver's side fender ready for paint & shot it. It has some imperfections, but my conditions really aren't on my side Here's some shots of doing it:
                Scraping off some excess bondo here, not exactly the preffered method, but it got the job done.
                Possibly the most annoying part right here. The angles to work with are terrible!
                And once the body work was done, it was painted.
                This shows some areas where I laid the paint on too thick and it bubbled:( Oh well, at least it will be fixed in the next coat.
                Then this guy snuck up when I was cleaning up. Bad decision bug(little orange dot). Not only did you die, but you managed to tear up the fresh paint:hitler:
                Got one of these things for free from a competition. Possible best thing ever. No more mixing in laundry detergent cups!
                And here it is on the car. Yes, it was still tacky when I put it on, but it was definitly worth risking it.
                It basically ties the whole front end of the car together
                • gp.plus
                  • 416
                  #83
                  Nice job so far, sub'd. If you soak the ground with water under/around the car right before you spray it will cut down a lot on the dust.
                  • AbsorbantNut
                    • Jun 2010
                    • 2491
                    #84
                    Yeah, for sure next time. Slipped my mind that time, but it just dries up so quick!
                    Considering doing this, it looks sick
                    Its Mr.cosmos's on e30tech btw.
                    Opinions?
                    • AbsorbantNut
                      • Jun 2010
                      • 2491
                      #85
                      Got another door painted yesterday. I'm almost halfway done with the first coat on the whole car. The next one's going to be so much easier I hope.
                      • AbsorbantNut
                        • Jun 2010
                        • 2491
                        #86
                        Yeah, so here's some pics of the door and a little walk through of what I did.
                        I started by masking some stuff off.
                        Masking off the insde of the door so when I grind the rusty bottom rails the metal doesnt get inside of the door and rust in there too
                        This one's just kind of an over all shot
                        Then the real work starts. Grinding down the rust. Took down more after this but didnt grab a picture.
                        Sanding and applying filler on the outer side
                        Big pain in the butt using bondo to fill in rock chips on the bottom. Took me so long to sand that stuff down. I really need to pick up some body glaze. Would make it so much easier
                        Almost all ready to be wiped down with some Xylene and painted.
                        Then after I wet down the ground I sprayed it. Came out pretty good. Still needs some more coats of paint, but much better than it was before.
                        And yes, I know I forgot to tape up the door lock. Realized that once I was halfway through the second coat
                        Some shots of the rails
                        And the finished project.
                        All in all not bad for a few hours work. Not looking forward to the body though, so I will probably do hte trunk next and then the hood, which needs a lot of work:D
                        • AbsorbantNut
                          • Jun 2010
                          • 2491
                          #87
                          Well, is there any feed back on shaving the rear emblem?
                          Yes, no?
                          • kalib0y
                            • Dec 2004
                            • 3620
                            #88
                            just leave it. Your going a great job though.
                            95 7.1L 16V E36 M3
                            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                            LIKE my Facebook Page! CLICK HERE
                            • briansjacobs
                              • 1278
                              #89
                              I like it shaved, nice and clean.
                              Brian Jacobs
                              • freeride53
                                • 11972
                                #90
                                Wow, you're doing a great job! Keep it up!
                                1983 Peugeot 505 STI
                                1992 Volvo 240 Wagon
