Absorbantnut's '87 325is
  • F34R
    sLaughter
    • 12376
    #91
    Wow, I thought it would never get done up right. You are doing one amazing job!
    I am guessing you don't have anyplace that is wind and dust free. Here is what you should do when you finish the body work:
    Go buy 8 10' 2x4s, roll of clear plastic 3' wide is good enough. Dig 8 holes 3 feet deep then bury them with 7 foot remaining out. Now get some roofing nails and cardboard. The cardboard is to keep the wind from tearing plastic free. Wrap your temp painting booth and park your car in there for a final painting. You SHOULD shoot the whole car at once to make an even coat. The temp booth will keep bugs and dust free from your finish color and the clear coating. Will also give a nice place for the paint to set up for two days to be nice and clean =)
    P.S. Most DIY places like Lowes have base grade 2x4s that are CHEAP.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • AbsorbantNut
      Non faccio funzionare questa merda
      • Jun 2010
      • 2491
      #92
      Thanks guys, it sure is one crazy ride:D
      Thanks, and you're right. No place, so its basically just been sprayed in my front & side yard. And thanks for the tips on the homemade booth. That would be an awesome thing to put together for the final few coats, and would be awesome I bet at keeping the bugs and dust out. Oh, and I am doing SINGLE stage paint guys, so just color. Not color and clear.
      Hopefully I can make some more progress this week!
      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      • MG325i
        • Jan 2007
        • 805
        #93
        damn dude, keep going at it.
        E30 325I > SOLD
        E30 318IS > SOLD
        E39 530I > SOLD
        EP3 > SOLD
        95 M3 > SOLD
        97 M3 > DD
        • AbsorbantNut
          • Jun 2010
          • 2491
          #94
          Well this is gonna slow me down a little bit. Seems that I will now need to spring some $$ for a tire for the vert. The whole sidewall is chewed up and basically paper thin now:o
          But I did manage to get a can of this stuff!
          Now I can finallly get those patch panels on! woo:D
          • AbsorbantNut
            • Jun 2010
            • 2491
            #95
            Here's todays updates. Ill post up some more pctures later of how i went about doing it, but it's not done yet
            Here's how it started at about 4
            And a few hours later we had this:o
            Not too bad for that harbor freight flux welder:p
            • ck_taft325is
              • Sep 2007
              • 6880
              #96
              Oh holy mother of BONDO. You have stock?
              Need a part? PM me.
              • AbsorbantNut
                • Jun 2010
                • 2491
                #97
                Haha, what? And no, that's just a cut up fender, I showed it a page or two back. I only just got to welding it
                • Butler
                  • Nov 2009
                  • 1613
                  #98
                  Holy Hell man! You've saved that damn car. I wouldn't have touched it with a ten foot pole, but you made it happen. I admire your dedication. Seriously really impressive.
                  -Nick
                  Originally posted by 87e30
                  First of all: calm the fuck down; second of all; cool story bro.
                  • AbsorbantNut
                    • Jun 2010
                    • 2491
                    #99
                    Ok, so heres the ste by stepp of me welding in the rear quarter patch.
                    First, I started off with the hole cut out when I was "de-rusting" it and making the patches.
                    Then hit it with the grinder to prep the edges.
                    Hit it with some weld thru primer
                    2nd coat
                    Removing the tape lines. Got some overspray, but it will be sanded off anyways.
                    Yeah, you can weld thru this stuff
                    Stripped the fender line of paint
                    Hit the patches with some weld thru primer too
                    Taped up in place. Put a few tacks on for good measure
                    Uh oh:( Starting to get some burn thru
                    Bad news, now the welder is only burning thru the metal, and no matter what I do I cant fill in the holes. Then in some places, I'm not getting any penetration with the welds
                    • OhioriderAaron
                      • 111
                      #100
                      No offense, but I would cut that all back out and get someone else to do it properly, or get a little more practice in before you try it again. Looks almost like you tried to plug weld the panel in place? Even the thinnest flux core wire and using weld through primer is gonna make a huge job like that a PITA. I hate that weld-through paint. You can get a small bottle of C25 gas for under $150 and some .023 wire for $10 and you'll have much better luck with your welding. Just my thoughts,
                      good progress with everything tho! :)
                      Ohioriders.com
                      OhioBimmers.com
                      • AbsorbantNut
                        • Jun 2010
                        • 2491
                        #101
                        Yeah, I was thinking about that today. Figured I'd give it a go anyways though, couldn't really do too much more harm to it. Not sure what plug welding is or C25 gas, but this was mainly just for a learning experience. I think that I will just cut it out, make a new patch, and take it to a shop and see how much they would charge to weld it in. I suppose that that would save me some money versus having them to everything.
                        Thanks:o
                        • Marcos
                          • 100
                          #102
                          Awesome
                          Yes a handful but kudos to your perseverance!
                          ... Greased Monkey ...
                          • AbsorbantNut
                            • Jun 2010
                            • 2491
                            #103
                            Haha, I hope so. Thanks:D
                            Well I've got the trunk almost all sanded up and ready to be shot. But finals are getting in my way:hitler: After tuesday though, I should be able to get a steady pace going!
                            • FugitivE
                              • Jul 2008
                              • 101
                              #104
                              the surfice that you are welding on the back fender is not even cleaned enough? take away more color then you should see that it's going to be more easy for you to handle the welding.. to start with..
                              • AbsorbantNut
                                • Jun 2010
                                • 2491
                                #105
                                So I'm guessing taking and grinding it down to bare; clean metal just isn't good enough? How much further should I take it:D
