the "I finally have a net positive income" project thread
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    #46
    Why are those bolts coming out and breaking?
    • lifeiskaos
      • 1709
      #47
      Originally posted by kronus
      m52 is boring swap.
      I will prove otherwise when I pick you up from the airport today :D
      • kronus
        • Apr 2008
        • 13032
        #48
        Because 3 was barely enough to keep the mount from moving around. When the third one sheared, two were definitely not strong enough to keep it together, so it flopped around even more, which sheared the second to last one. When one was left, it snapped in about a day because it alone couldn't hold up the rest of the motor.
        mitchell: fair enough. I'm a bit scared :o (also, United)
        cars beep boop
        • einstein57
          • Jun 2007
          • 10780
          #49
          Sweet. You guys can come to my house on friday and help me fire my car up for the first time.
          www.gecoils.com
          • robrez
            • Jul 2008
            • 3376
            #50
            Yup! I have a job! This means that I can finally afford to do all that maintenance I have been skimping on.
            In this country, you gotta make the money first. Then when you get the money, you get the power. Then when you get the power, then you do the maintenance :nice:
            January 2012 COTM
            • freeride53
              • 11972
              #51
              six five oh bimmahzz? lolol. It looks great, I really love the Alpina theme.
              I really have been liking early models more than late's the euro bumpers make everything look sooo nice.
              1983 Peugeot 505 STI
              1992 Volvo 240 Wagon
              • kronus
                • Apr 2008
                • 13032
                #52
                Weekend. Did work!
                First, I got a 90 degree drill attachment, an EZ-out kit, and a T-handle tap driver. A buddy came over and helped me out, and we managed to get three of the four snapped bolts out of my block. Jacked up the motor, put in a new motor mount arm, applied loctite to the three screws we could use, and tightened it down. 75% of my weird engine noises are now gone.
                Old mount, cracked and otherwise mangled:
                Snapped-off fuckers in the block:
                Removed:
                Also at this time I installed a convertible front sway bar. The size difference is pretty small (20 vs. 22mm), but eh, I got it for cheap, why not put it on. Also, swapped out rear sway links for new ones.
                Today, I pulled my cluster, and resoldered every connection. Now, my cluster lights work without having to hit the dash, which is awesome. I also installed a 7K tach (I'll need it in the future :o), and replaced my Motometer speedo/odo with a VDO unit that didn't have messed up gears. The speedometer part works fine, but the odometer is nonfunctional :(
                Doin' work :)
                cars beep boop
                • accident
                  • 7303
                  #53
                  your car sucks
                  Moral of this story?
                  • kronus
                    • Apr 2008
                    • 13032
                    #54
                    Originally posted by accident
                    your car sucks
                    yeah :(
                    cars beep boop
                    • accident
                      • 7303
                      #55
                      needs more m52
                      • kronus
                        • Apr 2008
                        • 13032
                        #56
                        needs more m52
                        too many valves and other things in the head
                        I would like a 1-cylinder motor with a piston the size of a bucket and two valves. It would idle like "BORP... BORP BORP... BORP... BOORP.. ...."
                        cars beep boop
                        • chadthestampede
                          • Jul 2008
                          • 3601
                          #57
                          ^hahaha
                          hurry up
                          Originally posted by LJ851
                          Feedback
                          • CorvallisBMW
                            Long Schlong Longhammer
                            • 13039
                            #58
                            Honda CRF450 swap?????
                            • accident
                              • 7303
                              #59
                              i could see kronus now, flogging his one cylinder of fury coming down the road screaming at everybody he passes "YOU WANT SUMMA DIS? HUH?"
                              • kronus
                                • Apr 2008
                                • 13032
                                #60
                                Rinsed it a bit today. Mocked up the Zender spoiler I've had lying around for ages. What do you guys think?
                                In the works:
                                rear mudflaps
                                different front lip
                                cars beep boop
