1991 BMW 325i Coupe - Build Thread - The end is in sight!
  • MaksV
    • 1042
    #256
    Ok so mucho progress today.
    -Sorted out oil level sensor
    -sorted out ICV
    -sorted out coolant sensor
    Things to do for the car to be road worthy
    -alignment
    -tighten exhaust (small leak somewhere)
    -get power windows working
    -replace broken wheel stud
    Things that I need to do before I am happy with the swap
    -build a box for DME and relays
    -get wiring cleaned up
    -plug coolant to TB lines and clean up engine harness
    Also I have sprung a small oil leak - not sure where from, but I need to get that sorted. Just happy to have her running strong finally.
    CHEAP REBUILT INJECTORS
    Need Quality Brakes? BimmerBrakes has it!
    For anything Else go with BluntTech!
    • MaksV
      • 1042
      #257
      I know I have not been updating this since I have not really managed to accomplish anything note worth in the last couple weeks. But here is the plan as I see it.
      Current problems:
      -Fix power windows/sunroof
      --I still cant figure out why these electronics are on the fritz, everyrone keeps telling me to look at the starter, but I have and all those wires seem correct to me. I need to do more poking around, but basically i have no +12V on the inside of the car.
      -Alignment (scheduled next Saturday early AM)
      -replace wheel stud (Friday PM)
      -Cam Sensor oring to stop the oil leak - hopefully friday as well
      Basically, once the car is running and driving correctly (and by the way it feels great driving from my garage to the front of the house :) ) I am gonna launch a tirade of cosmetic stuff.
      Near future:
      -DME enclosure - thinking of building one out of brushed aluminum
      -M3 engine harness cover plastics
      -Install AC compressor and new lines
      -finalize ride height.
      -redo interior carpet
      --weld in new studs for seat
      --run real audio wires.
      -build bracket for PS res.
      and as always there is much more, but this should carry us through winter break. and I have to do some work on the bike too at some point.
      • MaksV
        • 1042
        #258
        I got the car aligned today, got the windows and stuff fixed last night.
        Turned out the 8mm wire was cut in the harness - reconnected it and everything started working as it should.
        The car pulls like a beast, its a bit loud, but sounds tasty.
        The new issue that has cropped up is that the brakes are acting weird. Basically no feedback on pedal, really sharp braking (tiny touch causes like 75% brakeing), and if i pump the brake pedal at a red light, the engine starts idleing weird and CEL comes on. Toughts?
        __________________
        • 328ijunkie
          • May 2007
          • 3961
          #259
          What booster you running?
          Check Us out on Facebook
          Full Product Line Tuning
          • MaksV
            • 1042
            #260
            Stock 325i. I simply move it over 1/2"
            • MaksV
              • 1042
              #261
              Today has been the worst day ever.
              Got my brakes fixed this morning. took it for inspection. Guy made me wait inside, he parked it near the dyno and let it idle for 30 minutes while he worked on other car. No airflow there. I came running out when I saw steam. Radiator is donesky. Had to tow it home. hopefully it is only the radiator.
              FML.
              Somewhere in that process it melted some wires together, causing them to completely melt everywhere (due to ground) I believe it is the the wire and relay to the o2 sensor heater. Can someone confirm:
              I am done with this shit. Need to get back to school work. Maybe as it cools I need to get some gear so I can ride my bike all winter long.
              • BrownBeanE30
                • 965
                #262
                the problem with ur brakes is the lil pin inside the master cylinder you have to shorten it a bit so ur breaks wont break like they do
                Originally posted by InuFaye
                silver is old man color car. you need dat BRO-SECA BLUE.
                so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
                An S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.
                • MaksV
                  • 1042
                  #263
                  Well i finally got everything fixed up last night and went to the inspection. Fail.
                  I managed to get the new radiator in, rewire the o2 sensor so it wont short itself, but the first test failed on Nox and HC. Guy told me to go drive the piss out of it at highway speeds to make sure the cat burns through, and reaches operating temp.
                  So i did. Car will shoot up all the way to 140 w/o a problem. AFR is spot on. but emissions is a bitch.
                  Came back and here are my numbers:
                  my number/allowed number
                  High Speed Low Speed
                  HC 88/114 147/117
                  Nox 1246/796 1456/879
                  The Nox didnt change after my drive but i managed to pass the HC high speed after my driving adventure. Guy said if its Nox it most likely the CAT not doing what its supposed to.
                  • MaksV
                    • 1042
                    #264
                    Ok. More updates. Its about time I know but life has been rough lately.
                    So I have my re inspection planned for Wednesday afternoon. The guy I need should be back by then so I can get my baby legal again. Drove it to campus though.
                    Today I decided to finally take care of the braking issue I was having. The solution was to buy an IX booster and master cylinder. This is definitly not something I recommend changing after you put the motor in if you can avoid it cause its a pain, but in my case it was a necessity.
                    A few intersting design notes. The clevis on the i/is/e cars is square, mak9ing it very hard to rotate to adjust length after the booster is in the car. The one on the ix booster is rounded off to make it easier. Much better.
                    steps required to removed old booster:
                    -drain all fluid
                    -remove res
                    -remove master cylinder
                    -remove TB
                    -unscrew and lift intake manifold.
                    -4 nuts on the back
                    -clevis and pin
                    All in all a lot of work and its a super pain to remove it still. Geting the new one in was much easier. After I started the car there was stuttering and gas spraying everywhere. Turned out I had punctured the small gas return line at the back of the engine. :facepalm:
                    So I fixed that and then spent close to an hour bleeding all the lines, since the master was completely empty it was hard to get all the air out. Honestly I can probably go back in a week and rebleed all the brakes to ensure minimum air bubbles. But now my brakes dont bind, arn't hypersensitve, and the car is once again a joy to drive.
                    Plans going forward(near future):
                    -Inspection
                    -Clean up engine bay
                    --harness cover
                    --bind all the hoses together
                    --paint windshield wiper jug
                    --power wash the **** out of everythign
                    -figure out and solve oil leak (perhaps the oil filter housing gasket)
                    -Redo interior
                    --new race seats(pair)
                    --custom carpet
                    --speaker wire instead of house wire :facepalm:
                    -new HU, speakers, ect
                    You guys can expect a lot of updates over winter break :4ngie:
                    Pictures:
                    Finally got the old booster out of there.
                    New booster in but here is another problem. I found a plastic 90* angle piece and had to hammer a bit of the strut tower to fit. This is a load bearing piece so I didnt want to cut anything.
                    Almost there:
                    Old clevis and nut, notice how its square making a pain in the ass to turn under the dash
                    My solution for the check valve.
                    A blurry look inside the old booster.
                    This thing just fell out. Dont think thats supposed to happen.
                    • MaksV
                      • 1042
                      #265
                      This was going to be a small update. turned out being a rather bad and big update.
                      Fixed the exhaust rattle. Apparently muffler shop forgot second band clamp and decided to tack weld it instead. Damn exhaust almost fell out.
                      Probably going to replace CAT with a small glass pack soon to try to quite sound down a little.
                      Put in a clutch stop - This was really necessary. Anyone need a stock piece?
                      Was about to leave, but then my mom yells she needs to give me something. So I figure I turn off the car and wait. Got the item, and then go to start car. Comes to life then dies. :headscratch:
                      The car cranks but nothign happens. Reset the computer, same result. Check fuel pressure next. Nothing. No fuel pressure. Fuel Pump relay seems ok. Check voltage at pump. 12V. hook power supply to pump - no sound, no fuel pressure. So pump is dead. I just cant seem to win. Now I gotta figure out if I want to spend $207 on a stock replacement. or get a Wallbro or TRE 255LPH pump. Thoughts?
                      • trackjunkie21
                        • Jan 2010
                        • 3962
                        #266
                        Got the Tre pump and haven't looked back, few thousand miles and not a single hickup from the pump itself.
                        Originally posted by Wh33lhop
                        VANOS: sometimes you just need to go full retard.
                        • MaksV
                          • 1042
                          #267
                          just ordered one. Will get to it when it shows up.
                          • MaksV
                            • 1042
                            #268
                            So a few days ago my fuel pump went (sort of) so I decide to order a new unit. Figured I would just got the 255LPH route for future boost or w/e.
                            TRE is a good alternative (cheaper) than walbro and seems to have good review. The E30 uses the TRE 340 unit.
                            Here is the link.
                            While not a complete plug and play (More LPH = bigger size) It is pretty simple. I did it for the first time in the dark with no problems.
                            1. Remove all carpets/seats/ect in your way
                            2. Disconnect Battery (recommended)
                            3. 4 phillips screws on the cover need to be removed
                            4. 4 8mm nuts and washers need to be removed from fuel level sensor
                            5. slide it out - ITS FULL OF FUEL (depending on level) so be prepared
                            6.Remove the small connector fuel hose.
                            7. Rotate remaining bracket COUNTERCLOCKWISE and pull it up
                            8. Disassemble and unsolder the connector wires - pay attention to the polarity
                            9. Cut the bracket for the larger nozzel
                            10.solder on new wires, assemble pump, dont forget the fillter
                            11.Put it back in the car - this time rotating CLOCKWISE
                            12.Put in the fuel level sensor and the cover and drive away - Also recommend replaceing that bit of fuel line if its old.
                            • Gnarles
                              • Dec 2008
                              • 342
                              #269
                              Nice writeup! I need to replace my fuel pump this winter and this will come in handy. :up:
                              • MaksV
                                • 1042
                                #270
                                Thanks.
