Your JY prices OWN local JY prices... $10 will get you a heater core valve and entrance fee lol.
Eta-to-M50: Build thread
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827 -
My previous build (currently E30-less)
http://www.r3vlimited.com/board/showthread.php?t=170390
A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsessionComment
Is your VC brighter then in pics? I was just curious if pics are a bit darker, cause that one guy has his done bright.Comment
So I was just changing the 2 metal o-rings behind the timing chain tensioner at the front of the head, get the first big one changed out, no sweat. Second outer one was a little harder, had to get my channel locks around the larger part, and get a socket on the smaller hex cap at the front. Break it loose, start threading the cap off. As soon as it gets to the end of the threads, the spring comes rocketing out with the hex cap on top...
... hits me SQUARE in the left nut.Comment
Ouchies. Guess you'll be wearing a cup next time you work on the car...IG: deniso_nsi Leave me feedback here
I absolutely hate that feeling. When that happens, not only do I feel like I'll barf, I feel as if I'm about to pass out from a drop in blood pressure.
You don't want more kids, right? ;)Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
shame about that gasket. Hope you got it fixedOk, the reason Matt posted this pic is because I have a very WTF moment going on right now. When I first put the thermostat back in, I put the new o-ring on the outside of it, like it's shown there, where it was when I pulled it out. So I put the new o-ring on, put on the gasket and put the housing back on, it smashed the gasket out because it was sitting on the o-ring.
So I got a new gasket today, and when I test-fitted the gasket, it still sits on top of the o-ring, and the same thing would have happened again if I had bolted the housing down on top of it. So I pulled the thermostat back out, and put the o-ring behind it, the thermostat on top of that, the gasket in place, and bolted the housing down. Everything fit perfectly. So... WTF???
Is the o-ring SUPPOSED to go into the opening in the head first, then the thermostat, then the gasket, then the housing? Because if I do it the other way, the gasket does not fit, and the housing will just smash the gasket out again, because it's sitting on the o-ring and not flush against the head. Will it leak, or be otherwise affected if I leave it installed as it is now?Comment
Yeah, it looks fine now. I'm pretty sure part of the fault must have been with that first gasket, because when I started to tighten it down with the new one, it started to push it out again, but it wasn't torn like the first one was. Who knows, I could have put a little tear in it myself, that material is super fragile. But that new o-ring that came with the kit was definitely thicker than the existing one, too. All kind of wierd.
I appreciate you getting me the new one so fast. I could have very well fucked it up myself, let me know if you want me to pay you for it.Last edited by Jand3rson; 03-12-2011, 08:19 AM.Comment
Josh Dont read into that. I didnt mean anything by it. I was sincere and just wanted to help get your project back on track. Nothing moreYeah, it looks fine now. I'm pretty sure part of the fault must have been with that first gasket, because when I started to tighten it down with the new one, it started to push it out again, but it wasn't torn like the first one was. Who knows, I could have put a little tear in it myself, that material is super fragile. But that new o-ring that came with the kit was definitely thicker than the existing one, too. All kind of wierd.
Its looking awesome.Comment
Nothing much to update recently, finally got my outer tie rod lock washers today, now I can put my front suspension back together!
Hoping to pick up a set of RTABs/RSFBs soon, then I just need to get my diff installed, and I can put the rear subframe back in, too.Comment
