Eta-to-M50: Build thread
  • 87e30
    • Jul 2008
    • 5676
    #1051
    10-11 is the proper maf position. I never thought it was for power more for design reasons...b ut what do I know I don't follow that rule.
    I know 24v is a MAF... just hadn't seen the NV maf before.
    You know what would look good in that empty spot? whooooooosh. :)
    I just hate everyone.
    No need for discretion.
    • A_Whelan
      • Jul 2010
      • 691
      #1052
      I am reading through he comprehensive DOHC thread and I just got into the position of the MAF, if anyone wants to read the talk starts at post #351
      r3vlimited Lanyard Group Buy!!!
      • 87e30
        • Jul 2008
        • 5676
        #1053
        ^ enough of a reason to run it at 10 o'clock for me. No reason not to.
          • 37829
          #1054
          My MAF is upside down (to hide the plug) and totally fine.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • AndrewBird
            The Mad Scientist
            • 11898
            #1055
            Is it 10 o'clock looking at it from the front, or from the rear?
            • Gobig_us
              • Jul 2008
              • 148
              #1056
              Looking good Josh. I really dig the contrast between the red and the black bedliner.
              • Jand3rson
                • 37587
                #1057
                Well, I got my bonehead sticker tonight.
                Started to bleed the brakes tonight. So we get thepressure bleeder hooked up, fill it with fluid, build up pressure, Andrew opens the bleeder valve at the rear caliper. Fluid is coming out, but VERY slowly, we're like WTF mate?
                So we get it (that caliper) finished, start jacking up the car from the end, and I see a steady stream of brake fluid dripping out of the front of the car. Discover that the fitting above the front frame rail, kind of under the booster, is less than finger tight, barely even on. So it was just pushing all the fluid that didn't go to the rear caliper out of that fitting.
                And to add insult to injury, about half the ATF I poured into the PS reservoir leaked out of one of the steering rack hose fittings, I was missing a crush washer on each fitting. I could have sworn they were on there, but apparently, they weren't! :D
                But those were the only 2 spots where anything was leaking from, and they were easily identified and fixed. And the bright side is that it's better to find these things now than when it's out on the road, spraying it everywhere. So I'm out about $15 for fluids and an hour of time. Oh well, get some new tomorrow, and go at it again!
                • KenC
                  King of Kegstands
                  • 14396
                  #1058
                  Get the brake fluid off of your paint asap.
                  Originally posted by Gruelius
                  • Jand3rson
                    • 37587
                    #1059
                    None got on any of the paint on the outside of the car, just down on the frame rail near that fitting. Mopped up as much of it as I could get to, it doesn't even seem to affect the bedliner at all, and this was almost 3 hours ago. Another hooray for the bedliner. If it was paint like I'd originally intended, that area would be a disaster. The bedliner isn't even gooey.
                    • Matt-B
                      The Waffler
                      • 3856
                      #1060
                      I have been in that kinda situation before, I drained my oil, forgot drain plug, poured 6 quarts of redline into a pan of black gear oil...
                      And like everyone else has said, i love overall look of motor :)
                      • BrewCity11
                        • Mar 2008
                        • 2335
                        #1061
                        Originally posted by NitroRustlerDriver
                        Just the air filter is KA Motors. M5x engines come with an MAF stock.
                        I wonder how it would look josh if you made a panel out of aluminum or steel to cover the area behind the headlights on the passenger side. This part I mean:
                        I just think everything in your engine bay is all smooth and flat except for that one area. Kind of sticks out. If there was a panel there, it would be all nice and flat. You could just use a few screws to hold it into place. Bedliner it to match.
                        How about carbon fiber to match the intake? You can find an 11" x 32" sheet (.015" thick) with adhesive backing for $50.
                        or
                        Go to a vinyl or vehicle wrapping shop and buy some carbon film. You could form it into grooves and over that triangle looking hump on the rail.
                        turk@gutenparts.com
                        • A_Whelan
                          • Jul 2010
                          • 691
                          #1062
                          ^ That seems like to much messing around for such a last minute thing and having huge panel of carbon fiber to match a small intake wouldn't look right. I do agree that a panel should go there to smooth it out.
                          • Simon S
                            • Oct 2004
                            • 3758
                            #1063
                            Work of art !
                            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                            • 416stroker
                              • May 2008
                              • 2448
                              #1064
                              Is it running?
                              84 318I Delphin RIP
                              87 325IS delphin 24v Sold
                              89 325 Alpineweiss
                              • Jparkr
                                HR Admin
                                • Jan 2006
                                • 3494
                                #1065
                                I was going to do that, I had a piece of aluminum cut out and everything, but the body shop fabricator said it will slowly vibrate through my paint and when the aluminum touches the steel it begins to corrode. You should be able to do it ok with bed liner, I just didn't wanna have to replace the plate in 4-5 years. Ill look around the shop and see if I still have the piece.
                                1987 PRO-3 car /1990 325is (2.7i Concours)
