I think the ECU won't fire the injectors unless the engine is turning over, so maybe it is turning too slowly to signal the ecu?
I would also put 5 gallons or so of gas in it as the tank is not only almost empty, but also empty with old gas.
You also might want to jump the fuel pump relay to prime the system. There probably isn't any fuel in any of the lines since it was all disconnected.
