Eta-to-M50: Build thread
  • Jand3rson
    • 37587
    #1456
    Evening the guy at the exhaust shop recommended the Dynomax, before I even mentioned it. He just said to make sure it's the chambered one, and said it would tone the noise down a ton and probably take away most of if not all of the rasp.
    Originally posted by scabzzzz
    Raspy on an M50 sounds kind of sweet. Its not a daily driver, why care?
    I don't mind a little rasp, but the whole system overall is super loud, and just doesn't sound good.
      • 37828
      #1457
      Well, then what I'm going to do for now is order the Dynomax super turbo, a single 3" in/dual out is only $65. Everything i've find online says they're super quiet and will do wonders for loudness on pretty much any exhaust system. The flowmaster doesn't eveeven seem like it has packing, mostly just baffles.
      Flowmaster mufflers are chambered. They don't have packing.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
        • 37828
        #1458
        I remember we ran one of those on a customer's M50 car. It was ebay headers, full single 2.5" exhaust, single cat, and the Dynomax. Super quiet and nice to drive. Yours should sound perfect since it has the Magnaflow in place of a cat.
        Grover Beach, CA
        www.BimmerHeads.com
        • Jand3rson
          • 37587
          #1459
          Nice. I'm going to get the 22" one, too. The 13" seems like it will be too short to do much good. What was the rasp like?
          • LJ851
            • 7918
            #1460
            All the Dynomax mufflers are very effective, they are not at all like a straight through. 22" inches should be very subdued, a grown man's muffler.
            Lorin
            The M30 is God's engine.
            • dannyb
              • Dec 2009
              • 27
              #1461
              any specific dynomax model or any will do?
              • bubbajan21
                • 1962
                #1462
                Are these E28 M5 rubber mounts?
                • shiboujin
                  • Feb 2006
                  • 2791
                  #1463
                  Look like stock GR260 ones to me
                  • Wh33lhop
                    • 11705
                    #1464
                    Those are regular E30 trans mounts with Mike's trans brace (should have been pink). The E28 mounts people use for 24V swaps are motor mounts, not trans mounts.
                    paint sucks
                    • bubbajan21
                      • 1962
                      #1465
                      In the "DOHC Swap Basics" sticky, it lists "E28 m5 or two 320i trans mounts/ which are cheaper." So do I just use stock E30 trans mounts?
                      • shiboujin
                        • Feb 2006
                        • 2791
                        #1466
                        E21 trans mounts are stiffer than the stock E30 ones. But both will work.
                        • Jand3rson
                          • 37587
                          #1467
                          Yep, those are stock rubber E30 trans mounts, and my motor mounts are E28 535i green mounts.
                          I was going to go urethane tranny mounts, but that pair was basically new. When the time comes to replace them, I'll probably go urethane, along with the motor mounts.
                          Ordering the new muffler tomorrow, but I'm still trying to decide if I should get the 13" Dynomax or the 22". After driving the car a bit today, all of the loudness that is really bothering me the most is up high and at WOT, at idle it really doesn't sound terrible, it's just too loud. There's only a $10 difference, but it's also a 9" difference, and I'm worried he's going to have to totally rework the piping going back to the muffler to make it fit, and make the tips come out right.
                          • bubbajan21
                            • 1962
                            #1468
                            I've seen all kinds of stuff with motor mounts, 2 green, 2 black, upside down mounting, etc. What is the best way to do it? 2 green? Do you know why 2 green is better than the stock e28 m5 1 green 1 black set-up?
                            • Jand3rson
                              • 37587
                              #1469
                              I just went with what Blunt recommended, he said he'd used the 535i green mounts on all his swap cars.
                              • AndrewBird
                                The Mad Scientist
                                • 11898
                                #1470
                                The only "reworking" he would have to do is cut the pipe back a bit farther. I would be more worried about the muffler fitting under the car more then anything. Might want to measure the area where the muffler goes to see if it will fit ok.
