Phase 2: search for more power
  • Bmil951
    • 53
    Sub'd.
    • tg318is
      • Jun 2008
      • 2052
      Yes
      Tim.
      • Schwarz325
        • Aug 2009
        • 487
        I wish mine came with an m42 i woulda gone the same route. Good luck man!
        Maybe i didn't read it right, how do you use a m50 manifold on a 4 banger? cut and chop?
        • Good & Tight
          • Apr 2004
          • 2057
          2" 1/2 piping to 3" IC is fine, all you need is the reducing silicone couplers and your good to go.
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • trackjunkie21
            • Jan 2010
            • 3962
            Yepp, chop the last two cylinder ports off, and cap the ends. Then you need a 45-50* adapter on top of that so the turbo doesn't hit the Valve Cover.
            Ordered that right now :p
            Originally posted by Wh33lhop
            VANOS: sometimes you just need to go full retard.
            • nespo_e30is
              • Apr 2008
              • 595
              Love this, and followed your thread when you purchased car... looking forward to the end result and I knew the owner of your car before. I will be watching, and love what you have done so far.
              Nunzio
              Creative Director & Professor
              Twitter
              2010 Vespa GTS300 | 2000 323iT Euro | 1991 RRC Hunter | 1987 325is (guten build) | 1983 Jaguar XJ6 Vanden Plas
              • trackjunkie21
                • Jan 2010
                • 3962
                Thanks! Here is a small update, just bought me one of these. $5 shipped from fleabay, also ordered the 3"-2.5" coupler for the intercooler. If I get all piping and couplers by this weekend, I think a test fit will be in order.
                  • 34844
                  please don't use a junkyard turbo :(
                  do some research on compressor maps and find a modern (efficient!) turbo that suits your desired powerband. It's the same amount of basic work but you'll end up with a much more reliable, efficient and responsive setup than a turbo from some random junkyard car made 20 years ago.
                    • 34844
                    Originally posted by trackjunkie21
                    Wouldn't the 3 inch inlet on the intercooler cause more turbo lag? Since it would need more air to be able to push through the larger diameter inlet/outlets?
                    not really
                    • kamotors
                      • Nov 2007
                      • 7102
                      awesome, can't wait to see it finished. I cheated and just bought a faster car and started modifying that to fulfill my need for speed.:)
                      7speedshop.com
                      • trackjunkie21
                        • Jan 2010
                        • 3962
                        I wouldn't just drop the Turbo in, I'd rebuild it :D I'm looking for something off a silvia or what not.
                        Thanks
                          • 34844
                          it's not that the turbo itself would be unreliable - but a turbo that is running outside it's efficiency range for your engine will run hotter and require more boost for the same power level. Hotter air at a higher pressure = less reliable. Since you are already doing all the other work, it doesn't really make sense to put a sub-optimal turbo in there - it's the heart of the whole setup.
                          Besides, almost all factory turbos are undersized and certainly anything 10 years old or more could not be considered modern. There is way more to turbo responsiveness than just putting a small one on there, that was 1990's thinking. :p
                          Buy some books and learn about compressor maps :D
                          • trackjunkie21
                            • Jan 2010
                            • 3962
                            Thanks for the info, any specific book you recommend?
                              • 34844
                              there's always the standard corky bell book. I have another one that I really liked for certain aspects of modern turbo chargers, basically how they function at a basic level. I don't remember the name off hand though. It also had compressor maps for basically every modern turbo, very handy.
                              • trackjunkie21
                                • Jan 2010
                                • 3962
                                Would the book be called Maximum boost? On another note, I was considering picking up a 16g turbo.
