E30 M3 Steel Bodywork Conversion
 No, that would be illegal. You can't take the VIN from one vehicle and swap it to another. This car started out as an 87 325E and it still is an 87 325E, by VIN. It has been modified, heavily at that, but that doesn't change the VIN. I did keep the section of cowl with the VIN, the title and the keys to the M3. I have them on a shelf, in my office... a tribute to the M3 that I owned for 4 days, but that's where they are staying... and the car stays an 87 E, by VIN...
 Garey
 Long time, no post... been busy, blah, blah, blah. Anyway, I have done a little work on it but I picked up a big piece of the puzzle this week and it came in today. Big thanks to Corey at Track One Motorsports for getting this monster out to me quick-like. It's a Mishimoto, Z3M, 3 row radiator and as you'll see from the pics, it's a monster! The very best part about it is, it's a drop in, 1 small mod install. Pics...
 And the one, small mod to bolt it in... 2 slits in the inverted round parts of the factory top mount...
 I have to shorten the upper hose by about 3/4" at the water pump nipple to get rid of the slight kink, but that's it... Pretty F-in slick and should cool the V8 without question...
 Garey
 Very nice and simple. I love it!Comment
 Radiator looks great!Comment
 Quick update and a couple of pics... I've been working on getting the brakes and clutch plumbing done and all of the associated hardware back on the car, which is going well. I got my brake/clutch reservoir in today, it's a Tilton 3 chamber unit, which I'm mounting where the blower motor used to go, behind the access cover. I'm also working on trying to finish up the component locations under the hood and I'm down to the power steering reservoir, so I'm making progress there, as well. I also put the car up on jackstands, so I have access to everything, without having to move it. That makes it much easier to work on, if I have a spare couple of minutes. Pics...
 New Tilton reservoir
 HVAC box block off plate with new home for the fluid reservoir
 Dual filter housing with Bosch spin on filters
 The oil cooler is mounted, still have to plumb everything, though. It's getting there...
 Garey
 I love the things your are doing! :) :) :)Comment
 Garey,
 Do you have any worries about the slits you put it the radiator 'mount'? I look at things like that I wonder when, not if, they'll fail. Please understand that I don't have ANY engineering degree to back that up or anything, but that looks like a less-well engineered solution than virtually everything else you've done. Perhaps I am just looking at it wrong; I just see a potential for heat/vibration-induced failure.
 Having said that, I ALWAYS love to see updates on your project!!‘Tis by the grace of God that my cars run!Originally posted by LJ851kingston is the play by play announcer for this thread.
 Siobhan's Build Thread - UPDATED!Originally posted by unloadedak#teamross
 The way I feel is if it makes the car better and it's better quality why not?
 Looks better, feels better or functions better then by all means- Yes!Comment
 Maybe I'll get another picture or 2 of the mount itself to better clarify the slits. They aren't in a place that affects the integrity of the part. I think the only way it could break is in an accident, which, then, I have bigger issues than a broken rad mount, lol. Having said that, I had also entertained the idea of fabbing steel clips to go into the E36 slots, at the top on each side, then bolted to the core support, so that may happen. I just like the look of that plastic mount, but we'll see...Garey,
 I'll sleep on it...
 Thanks man,
 Garey
