Project 88 325is, vert replacement (because racecar content) -- R. I. P.
  • Justin B
    Sikky Nar Nar
    • Mar 2005
    • 4273
    #196
    Ok, its late enough I should add todays pictures in. the unloader relays have me looking a little crosseyed, but im looking into how to replicate their functionality, or enough that it makes this thing run.
    Thanks a lot! I really apreciate the comments guys. Makes it just a little easier to burn midnight oil on this project.
    Some hand filing the tops and bottom outside corners like this..
    To get clearance like this, no spacers...
    Top
    Bottom
    Yeah, its a tight fit 8)
    I also rolled my rear fenders so the rears would clear for sure after an alignment.
    Some stance shots, un settled
    • drutt23
      • Feb 2011
      • 392
      #197
      Are you going to do some sort of skirts eventually??? I don't remember if you mentioned it already or not.
      1989 325i|1992 325i|And completely obsessed|:woowoo:
      sigpic BMW. The Ultimate Driving Machine.
      The Build...
      • Justin B
        Sikky Nar Nar
        • Mar 2005
        • 4273
        #198
        Yeah, eventually. Not yet, no need.
        In other news, its not my unloader relays causing my no run issue. At least im 90% sure. All that wire does as I can tell is ground the relays except when starting, it goes hot I guess. Tried plugging it into the on side of the ignition switch to be hot at run/start since that is what is at the other end of the unloader relay coils, but once I turn on the ign, the starter motor spins, so that idea seems out unless im missing something there. I'm obviously missing something here, and don't know what it is.
        Heeeelp
        • Justin B
          Sikky Nar Nar
          • Mar 2005
          • 4273
          #199
          Long story short, it starts. I had the start signal to motronic wired to my start button, it needs to stay hot if the engine is to run, so I wired that too to my ign switch.
          With raising the subframe, and having the adjusters welded on, it makes it nearly impossible to adjust camber. The subframe probably will need to be dropped to make some clearance by grinding or a bfh. I think it should be ok to drive though, and I have an 8am 4whl alignment to make in Petaluma. Maybe they have some magic touch. Otherwise ill deal with it later. I tightened them down as best I could, and set the toe adjusters roughly at the same location.
          So what's left for sure is try to program my dash, speedo, tank capacity and water temperature. 4 wheel alignment and smog. Technically all I need need, but there are other little issues to take care of, just not as critical for the trip...
          • Justin B
            Sikky Nar Nar
            • Mar 2005
            • 4273
            #200
            Theres another vid on photobucket. Id use youtube but it wont upload unless im on wifi, pb took it on 3g.
            • e30polak
              • 6136
              #201
              Wow Justin, great work on the car! Can't wait to see it all buttoned up! :D
              Also interested to see the weight of this thing! :woowoo:
              INSTAGRAM: @UNDR8D_EMPIRE
              • Justin B
                Sikky Nar Nar
                • Mar 2005
                • 4273
                #202
                Might jyst have a chance to curb weight it in washington while I an up here.
                It does run again. The pilot bearing let go of half of its balls, and the alternator died.
                • Justin B
                  Sikky Nar Nar
                  • Mar 2005
                  • 4273
                  #203
                  Just got to James' house after the lake house 4th of July. It was a blast. Ill probably be up in WA/portland v for a while.
                    • 37832
                    #204
                    Awesome! Glad you got it running and glad you're havin some fun.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • Justin B
                      Sikky Nar Nar
                      • Mar 2005
                      • 4273
                      #205
                      Car is currently in my parents driveway for the winter in CA. I need to get it to a suspension shop so they can diagnose my wannabe-g-leaning car. It sags hard on the pass rear (and has less suspension droop than the driver side rear, wtf? subframe is the same height), causing the DS front to look 4x4ish.
                      I have an answer for you on weight though, a couple months ago I drove across scales in Tacoma, and with me(150), a half tank of gas(40ish), spare arc-8/tire(40ish), and a bit of stuff in my trunk (~30), the car weighed 2780. So, 2600 on the heavy estimate side.
                      • Justin B
                        Sikky Nar Nar
                        • Mar 2005
                        • 4273
                        #206
                        Dark after midnight too fast around a decreasing radius turn. Was an unfamiliar road.
                        Misjudged, hardcore.
                        R3V'ed my car big time, 2 days before my birthday.
                        • Justin B
                          Sikky Nar Nar
                          • Mar 2005
                          • 4273
                          #207
                          No (major) injuries, was a hell of a ride though. Safety parts (cage seat belts) did their job very very well. Extent of my injuries is sore spot on my leg from the door X bar, a black eye and bruised eyeball.
                          That was this morning about 2am.
                          • Justin B
                            Sikky Nar Nar
                            • Mar 2005
                            • 4273
                            #208
                            This is the last pic I ever took of it.
                            • Cabriolet
                              • 9620
                              #209
                              Oh DAMN! sucks for your loss and glad you are able to walkaway.
                              Much wow
                              I hate 4 doors
                              • kronus
                                • Apr 2008
                                • 13032
                                #210
                                oh fuck, that's a solid r3v. sorry dude.
                                any salvageable bits, or is the whole thing toast?
                                cars beep boop
