MGB + M42 = Win
  • AndrewBird
    The Mad Scientist
    • 11898
    #121
    Made some decent progress on the oil pan. Started out making a jig to bend the outside walls of the pan. Basically it is two sheets of plywood with a few chunks of 2x4 to space them apart. Then all I had to do was bend the metal around it.
    Out of the "form":
    In place on the flange:
    All the bends turned out perfect, I could be happier about how it worked. Only one problem though. Somehow it ended up about a 1/4" too short. So I have to make a new jig that is a bit longer and re-bend it. Oh well. We'll call this one the prototype proof of concept. ;)
    Once I get one to come out the right shape, I'll trim the ends and weld the seam, then notch the back corner where the oil pump pickup is. After I weld it to the flange, I'll trim it to the correct shape height-wise and weld on a bottom, a tube for the dip stick and a bung for the drain plug.
    • AndrewBird
      The Mad Scientist
      • 11898
      #122
      Got a bunch more work done on the oil pan. Outer wall is all welded into place. Still need to sand/grind everything smooth, but it's together!
      All welded on the inside:
      Lots of 1" long welds.
      Small mistake I made. I didn't allow enough clearance for the bolt head/socket to fit, so I used a piece of tube to give me some clearance. That hole you see is going to be welded up.
      Quite a bit of the height will be cut down. It is going to be similar shaped to an M20 with a large sump part and then a thinner section that will be made to clear the subframe. The thinner section is less then 2" tall and the sump part is ~1/2" less then the height it is right now.
      I plan on getting it cut down, weld a bottom on it, and then start on the oil pump pickup. Need to install a tube for the dipstick as well, but that can come last.
      • blalor
        • 217
        #123
        Nice work! That cutout for the socket is really clever.
        • DTM190
          • Nov 2008
          • 1107
          #124
          Hey Nitro, did you bolt your flange to a flat surface while welding it? Reason I ask is that a place that I used to work made a lot of custom sumps/oil pans and they always bolted them to a jig while welding them to avoid the flange warping so that it seals nicely or are you planning to have it faced once you are done?
          Originally posted by der affe
          first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
          if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
          • AndrewBird
            The Mad Scientist
            • 11898
            #125
            I didn't bolt the flange to anything. It is 1/4" plate though, and with as slow as I welded it, it didn't warp (already checked it). I was very meticulous about it so it didn't warp.
            • Matt-B
              The Waffler
              • 3856
              #126
              Nice work andrew, very happy to see you shoe horning a m42 in a MG
              I have a soft spot for MG, triumph, norton, etc :)
              • freeride53
                • 11972
                #127
                That's some cool ingenuity. Love it!
                1983 Peugeot 505 STI
                1992 Volvo 240 Wagon
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  #128
                  Lots more done tonight. Ground down all the welds so everything is nice and smooth. Then I cut the sides down to their final shape and started working on closing up the bottom. Got the first two pieces cut and fit, but need to buy a new cutoff wheel before I cut out the big piece. Also started working on the oil pump pickup.
                  Welds all smooth and rounded:
                  Sides cut:
                  Bottom plating:
                  The hole for the oil pump pickup:
                  The piece to box it in:
                  Sitting in place:
                  For the oil pump pickup, I plan on boxing it in with the piece I made and then running a tube off of the box down to the bottom of the pan. I'm going to build a flange that will bolt to the box so it will be removable so you will be able to replace the pickup if needed. I'm going to try and use a Chevy Astro Van pickup as it is big and flat and easy/cheap to get. Here it is here:
                  • DTM190
                    • Nov 2008
                    • 1107
                    #129
                    Nice work mate, coming up well
                    • SpoolnDaapex
                      • Jan 2010
                      • 150
                      #130
                      That pan is looking great! :up:
                      M42: Because 110 feels like 140 :finger:
                      • Jand3rson
                        • 37587
                        #131
                        Got to see this in person tonight, and it looks amazing. Andrew's work is very precise!
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          #132
                          So I didn't like the look of any of the oil drain plug bungs that I could find, or if I did like them, they were aluminum, so I made one.
                          Sitting in a scrap piece of metal.
                          It will be welded to the pan on the backside. Uses an M12 drain plug. I'll probably get a different drain plug other then this one as it is kind of tall, but it worked for making the bung. Might just cut the head down slightly.
                          • Simon S
                            • Oct 2004
                            • 3758
                            #133
                            Hot day-am! You do nice work.
                            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                            • Jand3rson
                              • 37587
                              #134
                              Heh heh... bung.
                              • AndrewBird
                                The Mad Scientist
                                • 11898
                                #135
                                Thanks.
