MGB + M42 = Win
  • Simon S
    • Oct 2004
    • 3758
    #91
    Sweet Jesus - your finished products are just pieces of artwork.
    Nice to see engine mounted up - for some reason, I thought lower pan would be 1/4" off the ground and a large hood scoop needed up top for clearance in that MG.. lol
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • Ryann
      • 3350
      #92
      That looks really good. Very precision looking.
      +1. Nice work.
      • AndrewBird
        The Mad Scientist
        • 11898
        #93
        It would be if I wasn't building a new, lower profile oil pan and notching most of my front subframe out. lol
        I think I got the shape of the pan worked out:
        It's 70mm deep in the front and 95mm deep in the back. The dashed line represents where ~5 quarts of oil would sit at. That line gives me 10mm clearance between the top of the oil and where the lowest part of the crank dips into the pan.
        I may cut it down to 4 quarts as I'm not sure there needs to be a full 5 quarts sitting in the pan. Any comments on this?
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          #94
          So, you are running a clutch fan? ;)
          • AndrewBird
            The Mad Scientist
            • 11898
            #95
            12" electric flex-a-lite. The one I was running with the MG engine.
              • 37829
              #96
              No worries about oil drainage from the head with your new angle?
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • AndrewBird
                The Mad Scientist
                • 11898
                #97
                Already looked into it and it won't be a problem. With the way the drains are in the head, sitting upright, it basically drains in a mirrored configuration (if that makes sense). I.E. - Instead of draining on the passenger side drains, it drains on the drive side drains.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  #98
                  Bit of a snag. Local machine shop wants $97 to cut the flange for the oil pan. That's a bit more then I'd like to spend. I'm going to see what I can find online, but it looks like I might just make it myself.
                  • LJ851
                    • 7919
                    #99
                    Have you tried a water jet company? Usually the least expensive way to get work like that done.
                    Lorin
                    The M30 is God's engine.
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      #100
                      What do you mean a water jet company?
                      • LJ851
                        • 7919
                        #101
                        Its a way of cutting metal. Its a computer controlled very fine nozzle that sprays water and an abrasive to cut metal, much like a plasma cutter but with not much heat. Google "water jet cutting services" You will become addicted .
                        Lorin
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          #102
                          Originally posted by NitroRustlerDriver
                          Going to have it waterjet cut out of 1/4" steel.
                          Way ahead of you dude. That's what the machine shop wanted $97 for. And that was with me sending them a DXF file all ready to cut.
                          • jakeb
                            • 1909
                            #103
                            My brother in law runs a water jet. I could have him get your a quote. He might even have some material on hand. Send me a PM if you are interested and you can get me the dxf/dwg
                            www.classicdaily.net
                            1970 m42 swapped 2002
                            1985 LS1/T56 Swapped e28 (557e)
                            www.blunttech.com - For all your parts needs
                            Follow me on Instagram for constant build updates @classicdaily
                            https://www.facebook.com/ClassicDailyLLC
                            • LJ851
                              • 7919
                              #104
                              Sorry, i missed that . When you said machine shop i assumed....
                              Lorin
                              • Farbin Kaiber
                                Lil' Puppet
                                • 29502
                                #105
                                What about milling the flange of the stock pan?
