Vert build/m20 stroker
  • trackjunkie21
    • Jan 2010
    • 3962
    #31
    How to you want to accomplish 230whp? That seems a little high for an m20 stroker. My friends 2.9 made 192whp with a cam and custom tune.
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
      • 34839
      #32
      Originally posted by e30rapidic
      /sarcasm
      haha, I actually bought those way back when for my '67 dart. Holy shit, what a waste of money that was! I think they were like $6 a peice or something, in 1997!
      • M3TROY
        • Apr 2006
        • 578
        #33
        230hp? Not going to happen, youll need boost to reach thoughs numbers.
        Otherwise your looking at 182-195 MAX.
        • e30rapidic
          • 2167
          #34
          I think we all did back then, just most won't admit! I tried them in my 325is....
          '87 325ic, powered by S50.
          • F34R
            sLaughter
            • 12376
            #35
            http://www.millerperformancecars.com...category_id=45
            Download the 2.8 stroker PDF and read the specs. I am just going by what I see from the dyno. I don't expect those high 200 numbers but this over all will be very good =)
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
              • 34839
              #36
              I'm skeptical of that graph. I wonder if it's bhp and not whp. there's no info on the motor either, 2.8 stroker can mean anything..
              if it's bph then the #s make sense.
              • LJ851
                • 7919
                #37
                Your engine only has 1 (one) camshaft. And you are going to need a big one plus all the other things a big cam needs to get your desired WHP #s.
                Lorin
                The M30 is God's engine.
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  #38
                  It's nice to dream big, but Metric Mechanic got around that number from a 3.1 stroker, you will still notice a huge amount of torque, My friends 2.9 was awesomely fast.
                  • F34R
                    sLaughter
                    • 12376
                    #39
                    Agreed, was thinking those #s are at the crank. Also no info is mentioned about cam setup or fuel management, as stated in my good night post.
                    I am trying to contact them as I type. I still cannot reach crank-scraper...annoyed
                    Current cars:
                    ~ '87 535
                    ~ '06 X5 4.8is
                    • F34R
                      sLaughter
                      • 12376
                      #40
                      Update: Talking to brother tonight and seeing if he wants to order the 284 cam. I thought he might as well since I am about to remove it and port & polish the head. Still could not contact Miller or Crank-scrapers. I will try after work again tomorrow.
                      After searching about cams I am going to go with the Schrick 284 with stock springs. Since I just rebuilt the head it needs nothing else.
                      -Should I get b25 replacement springs or is there something else?
                      -Do I need one of these with the 284 cam? If so should I have the block skimmed .5mm?
                      http://store.nexternal.com/ireland/c...gine-p750.aspx
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                      • F34R
                        sLaughter
                        • 12376
                        #41
                        Just got in a box from blunt =)
                        I am awaiting crank from forum member
                        Schrick 284 cam from Vac
                        Adj cam gear from IE
                        Timing belt Tensioner/bolt and spring and valve springs from Steve
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                        • alwaysinabimmer
                          • 337
                          #42
                          Thanks for taking the time to share this- might be doing the same with my vert.
                          87 E30 Vert Alpine DD May-Sept
                          04 E65
                          06 Denali XL
                          GMC RV- Fall weekends
                          Larson Boat-Summer Weekends
                          84 E30 318 project/part/sell?
                          91 318is parted- some parts left
                          Sold:(
                          98 E39 Sport
                          97 E38
                          95 525i
                          95 E34
                          87 524td
                          87 535is
                          (OO=ll=OO) "E30 owners seem to have wheels like some women have shoes"
                          • Wh33lhop
                            • 11705
                            #43
                            Definitely need videos when it's all buttoned up.
                            paint sucks
                            • F34R
                              sLaughter
                              • 12376
                              #44
                              You are most welcome, that is why I am doing it. I could not find a thread that covered places to buy and parts #s and a end price. I have all parts #s and total price so far to give you an idea of money needed to complete this. Also to save time, I have spent HOURS on HOURS of tracking down the needed part #s and correct things needed to make this work. I am also covering how to make your own m52 crank spacer.
                              Granted I am doing a FULL rebuild, so the price is a lot higher...s50 swap higher almost xD I am saving him money because I rebuild engines. Only thing that is being done at a shop is: block and head dip/bath and balancing the crank, rods and pistons.
                              How about a few dyno pulls too? That is going to happen too, I am doing everything people ask in other threads. I want it so someone can come and read one build and not need to save shit tons of sites to get it done =)
                              I will also be putting up a video w/pictures on what is needed to do for a port and polish.
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
                              • F34R
                                sLaughter
                                • 12376
                                #45
                                So I am waiting for a tranny to come in for a car that is getting worked on at the garage. So when that is done Tuesday the b25 is coming out and head work will begin. Sorry for the slow updates, but parts are being shipped in and shop is busy. So maybe I can get it in for a late night pull on Wednesday =)
                                Till then I will leave you off with this bad boy! It just got in today! (284)
                                Current cars:
                                ~ '87 535
                                ~ '06 X5 4.8is
