Hey guys! I have yet to post any of my e30 related bits on R3V!
I bought this car from Eluk(some may know him from his mtech2 m50 days) in 2008 i believe and it looked like this
Then I had drove the car for a bit and decided I wanted some wheels and bought some gold rotas and had them for like 1,000miles before I realized I didn't like them once i got back from Bimmerfest 2009
I also had purchased IE3's and Billy Sports which i only got the fronts installed before I realized I wanted coilovers (lesson learned). I then sold the suspension to Eric and the wheels to someone else, they on the board but never post.
On to the good stuff!!
I wanted to do an engine build and turbo whatever i went with. I chose the M20 as people tend to ditch it and I wanted to see how much power I could make on a 12v SOHC. This wasn't going to be a budget build so i knew with the right stuff I could make gobs of power. People have been known to get 400hp+ on stock internals with stock cams so i think i should be pretty good. This is going to be mostly a street car, not DD, with some track usage as well. I may weld in a rear cage setup but not doing anything full as I dont want it solely to be a track car, no trailer for me, must be street legal haha.
Engine Details: 2.8l m20
M20 block bored 1mm over to 85mm*
JE 85mm Pistons with total seal rings*
O-ringed block*
ARP Main/Head/Rod studs/bolts*
S50 Rods*
ETA Crankshaft*
Ported & Polished Head with valve job*
Schrick Valves*
Schrick 304 Camshaft*
Schrick Valvesprings/retainers*
IE "beefier" rockers*
NUKE adjustable cam pulley**
PRD cam sync plate**
666 Turbo Manifold 6-1*
Tial 44mm wastegate**
GT3582R turbo (or similar)**
Ebay Intercooler **
Siemens injectors**
VEMS 3.3v*
AKG 75D motor/trans mounts*
Suspension:
E30M3 struts (cut and welded with new perches)*
Ground Control coilover setups*
Koni SA's (top adj all around)*
E30M3 rear setup*
Monoball trailing arm bushings*
AKG Aluminum subframe bushings*
AKG Aluminum diff bushings*
THR FCABS*
All new CA's & Tie rods*
SS brake lines*
Shoes:
BBS RC090
* Purchased
** Either on the way or not ordered yet
I am sure there is much more but these are all that stand out off the top of my head
My goal with this project is to be above 500hp (crank)
Stage 2 will be 500whp... which will include rods, rockers, and intake manifold
I have been collecting parts for about 2 years now and its definitely taking a lot longer than anticipated but I want it done right and done right the first time.. and sadly that does not come cheap, but that's half the fun!
Here are some pictures..
gutted carpet
obviously theres another box..
lots of work to get done :P
thanks for looking! will be updated soon!
Austin
O-ringed block*
S50 Rods*
ETA Crankshaft*
Schrick Valves*
Ebay Intercooler **
Siemens injectors**
VEMS 3.3v*
Suspension:
E30M3 rear setup*
THR FCABS*
SS brake lines*
Shoes:
BBS RC090
* Purchased
gutted carpet
Austin
