E30 Rally Build Thread
  • MasterOfPuppets
    • Feb 2011
    • 135
    #91
    Sunroof Patch and Vent - Post 2 of 3
    Here's the vent I bought:
    9" by 4" opening, aluminum, 1.25 lbs. Very solid construction, from an online van supply store called Mill Supply. I applied some appropriate sealant to the vent (roof & flashing, I think):
    As a note, the amount above turned out to be waaay too much, I would use half that much or less.
    I slapped the vent in place and riveted it down, again with 3/16" aluminum rivets. Here's how it looks from inside and out:
    In the meantime, I was prepping the roof for a coat of paint since the original stuff was mostly gone and looked terrible. Mid prep:
    As has been discussed, the paint job was botched. I tried both rustoleum "aluminum" and "metallic silver" to no avail. The only good news is that the metallic silver has great reflectivity. At one point I measured surface temps of the colors on the car, all at the same angle and in the same light, on the same material. The flat black hood was 130 degrees, the stock silver paint 100, and the rustoleum metallic silver 90. So it functions, at least.
    It was then time to apply the patch to the roof. First step was to align the patch on the roof. I was able to use a C-clamp to hold it in place while I lined it up from beneath using some lines I'd drawn to mark the edges of the hole.
    Once I had it aligned, I drilled the center holes front and rear but didn't rivet yet as I still had to apply the sealant. The two holes would let me line the patch back up and secure it quickly once I had done so. Here's a partially obscured cell-phone photo of the sealant:
    That amount and location worked well, I had no overflow to the inside or outside of the patch.
    Post 3 next.
    "WRC is for boys. Group B was for men!" - Juha Kankkunen
    CO's premier forum for all things rally - coloradorallyracing.com
    • MasterOfPuppets
      • Feb 2011
      • 135
      #92
      Sunroof Patch and Vent - Post 3 of 3
      I didn't take any pictures during the riveting process, but I basically started from the center in the front and rear and worked out to the corners. I did the front corners, then came back down the sides to close it up at the rear corners. The corners, especially the front, were tricky since the roof had curves there and the aluminum didn't want to follow. I semi-solved this by applying huge pressure down on the rivet gun as I popped them off. There's a small, almost unnoticeable gap in some places, but it will definitely still seal. I also had to forego using washers on the bottom... I don't have enough hands to pull that off alone. And yes, 136 rivets is a great grip workout. Here's how the whole thing came out:
      From the inside, you can see where in the roof structure the rivets attach:
      And finally, a comparison of the vent open and closed:
      I went and took the car for a drive to test it out. The vent moves a huge, almost surprising amount of air into the car, with the rear windows cracked or closed. And with where I put them, the air hits you almost square in the face, which could be good or bad depending on the situation.
      Overall, I think it looks great, it's very solid, it functions well, and it doesn't build up much heat, so I think it's a success. I'll post final pics when the second vent shows up and I install it.
      • JasonBates
        • 265
        #93
        That's so sick. i really love where this is going. I can't wait to see more.
        '87 325e 2.7i/5spd
        '02 Subaru outback (Still smells like dirty hippie)
        '86 635csi (Sold)
        '87 4KcsQT (Sold)
        '84 318i (Sold)
        • MasterOfPuppets
          • Feb 2011
          • 135
          #94
          Took the car for a drive down to my local gravel S-turn. Practiced some heel-and-toeing, which is made very easy by the combination of a slippy clutch, tiny engine, and good pedal placement. Also reinforced the point that an LSD-manual trans combo gives you much more control over the rear than the open diff/slushbox combo I'm used to. Gonna take a few laps at CORE to sort it all out.
          Also, I blew the excess nylon off the dash to see the final result. There are a few thin spots due to the drying adhesive, but it will definitely work. The photos make it seem a shade worse than in real life, but not much.
          Tomorrow it gets put back on. Gonna be sweet.
          • iamsam
            • Jun 2008
            • 174
            #95
            Nice!!!! I like how the inside of your sunroof panel looks exactly like the sky. That first interior shot made me do a double-take, it looked like you just installed a sheet of glass instead of the aluminum.
            Also, its a bummer about that clutch, I wonder why it slips so bad....
            • MasterOfPuppets
              • Feb 2011
              • 135
              #96
              Looking at it now, I see what you mean. I should have done it deliberately with a better color, it would have been cool.
              I assume it's something that can be fixed, but from what I can see, not from outside the bellhousing. Which means while I'm in there I'll just install the binary race clutch and call it good. Which means I'll just wait for this one to burn out.
              • iamsam
                • Jun 2008
                • 174
                #97
                I approve of this plan.
                • MasterOfPuppets
                  • Feb 2011
                  • 135
                  #98
                  Dash Re-install
                  I slapped the dash back in today along with the instrument cluster and a shift light. The shift light I bought, the cheapest one from Summit Racing, turned out to be waaay to weak for use during the day. I'll try to crack it open and replace the super weak bulb with a decent LED. Here's how the car sits now:
                  And most significantly, here's a shot from the driver's view, facing straight into the sun, at roughly 3 pm, at 7000' altitude, on a clear day (i.e. the worst possible condition for dash reflection on the windshield):
                  The bright spot you can see just above the drivers' side front corner of the hood is the reflection off the VIN plate. This flocking stuff flocking works!
                  • iamsam
                    • Jun 2008
                    • 174
                    #99
                    Yeah it is really noticeable that the flocking is so much less reflective than even the flat black hood. Maybe you should flock the flocking hood too.
                    • Dj Buttchug
                      • Jun 2010
                      • 7647
                      #100
                      i really want to do this to my dash. it looks so awesome.
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • SlapDash
                        • Jan 2009
                        • 675
                        #101
                        There's nothing like a good flock on the hood of a car...
                        www.slapdashracing.com
                        • MasterOfPuppets
                          • Feb 2011
                          • 135
                          #102
                          Flocking on the hood might be the way to go, although I'm more of a back seat kind of guy (Sam is too, right? Remember that one time with Kara in the Saab, testing the brakes? Good times.)
                          I have a few recommnendations if you do:
                          1.) Buy extra fibers - the 3 oz bag I had was barely enough
                          2.) Do it on a cold, humid day so the adhesive lasts longer. Mine was dry just as I finished up my fibers. As long as you're not in 5% humidity at 7000' in NM it should be fine.
                          • SlapDash
                            • Jan 2009
                            • 675
                            #103
                            The dash really does look good. Roof does too!
                            Do you settle on a cage builder? I talked to my guy and he would sell you a pre-bent cage that you can weld/have welded in locally. If you're interested, I can ask him for a price.
                            His car's sittin' in my driveway right now. My car's getting the skid plate, diff cup and other bits put on. The only problem is, after driving his, I don't want to give it back!
                            • drutt23
                              • Feb 2011
                              • 392
                              #104
                              What is the product you used for the dash?? It looks good. It'd be cool to use so that i could salvage my cracked dash and not have to source a new one. It seems like all the cracks in yours filled nicely. The car is lookin good by the way. I like your ideas man!!
                              1989 325i|1992 325i|And completely obsessed|:woowoo:
                              sigpic BMW. The Ultimate Driving Machine.
                              The Build...
                              • iamsam
                                • Jun 2008
                                • 174
                                #105
                                whoa whoa WHOA now...
