M20B29 w/ Triple Webers into my '71 2002
  • SkiFree
    • Jun 2011
    • 2766
    #136
    Hidden Stereo write-up.
    Let me be VERY upfront, I am NOT a stereo guy, none of this would have been possible if it had not been from input by several members here and on the faq board (Micah, Marshall, Stereoinstaller, Andrew, ken, and others).
    The goal, completely hidden, ipod controlled stereo setup that retains a Becker head unit.
    The speaker, wiring, and amp specifics is on the wiring diagram, if someone wants it (a lot larger and legible file) please email me.
    MATERIALS.
    ...were mostly from Jo-Anns (my wife loves pointing that out to me everytime she gets in the car).
    -marine-grade black vinyl which surprisingly matched the original vinyl perfectly. (for front console and front speaker panels)
    -open-cell foam (for rear speaker shelf)
    -Headliner foam (for front speaker insolation)
    -speaker cloth (for rear speaker shelf and front speakers)
    -black micro-suede (for center ash tray)
    -dynamatt (for rear speaker shelf)
    -wood (for amp shelf and rear speaker shelf)
    -interior carpet (for amp shelf)
    CENTER CONSOLE:
    Re-wrapped in vinyl, on the center ash tray I used a dremel to whittle away at the retention clip to allow clearance for the ipod. Wrapped the inside with micro-suede/
    Made a hole in the backside for the ipod connector.
    Enlarged the stereo opening for becker and made backside support arm (ran a new cheap speaker for the becker).
    Finished off with this beautiful hand-made shift knob by David (I think it’s proportioned perfectly to the car, not diminutive like the alpina knob).
    (http://www.bmw2002faq.com/component/...opic/t,379457/ )
    FRONT SPEAKERS:
    Driver’s side, I used the stock under dash panel, (Thanks to Ken Blasko). Cut out speaker hole wrapped it in vinyl, insolated the backside and stretched over some speaker cloth.
    Passenger’s side, made new panel as the stock piece was warped to badly. Repeated same steps as driver’s side.
    REAR SPEAKERS:
    Basically copied what Marshall did, new rear panel attached speakers. Layered the dynamat, foam and speaker cloth. Micah gave me the idea to use bang matts for the rear speakers to sit in. The bang matts help to seal the rear panel keeping out fumes, plus you can’t see the ugly speakers jutting into your trunk.
    AMPLIFIER
    I made a little wood shelf that fit in nicely (covered in carpet), mounted the amp and signal booster to it. Drilled a couple of wire access holes and was set!
    Wired everything up according to the diagram…..
    The volume control knob is the old choke-cable knob on the steering column. Welded a piece of the old threaded cable end to the JL-supplied supplied adjuster, and wah-lah!
    The interior looks better than it has in a long long time, now it sounds better too!
    ADAMS Autosport
    • catuned
      • Jun 2011
      • 2324
      #137
      Very slick!
      Work We Do
      CAtuned Feedback Page|FB CAtuned Page
      http://www.catuned.com
      • F34R
        sLaughter
        • 12376
        #138
        That Nardi <3 loving the build, looks so good.
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
        • Cronopoulos
          • Jul 2011
          • 2187
          #139
          That looks absolutely awesome! If you hadn't of shown me where the new stuff is i would not have guessed.
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • deutschman
            • May 2008
            • 5958
            #140
            Looking good! Hey sorry my offer of making you a shifter knob never panned out. I really thought I had everything worked out and then it just fell through and never ended up coming to fruition. If you'd like me to send that knob back to you, I still have it.
            • SkiFree
              • Jun 2011
              • 2766
              #141
              thanks F3ar, Igor, Kyle!
              Jeremy, don't worry about the knob, all too aware how "Life Happens" sometimes.
              * I'll try proofreading this, looks like some bits were missed.
              ADAMS Autosport
              • CorvallisBMW
                Long Schlong Longhammer
                • 13039
                #142
                Yes! Fantastic work on the stereo
                  • 37832
                  #143
                  Andrew, that's amazing!
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • EREKSHUN
                    • Apr 2011
                    • 310
                    #144
                    Jaw Dropping and very inspirational!!!
                    sub'd
                    • SkiFree
                      • Jun 2011
                      • 2766
                      #145
                      Sorry for the lack of updates, finally getting back to the engine. Decided to say screw it, I'm going 2.9. Starting to get Ignition and Fuel squared away as well. Just need more hours in a day.
                      Got the sidedrafts now.
                      Broke out the Dycum to start on the cylinder head.
                      Love me some new tools too, now all I need is some cunifer tubing!
                      ADAMS Autosport
                      • F34R
                        sLaughter
                        • 12376
                        #146
                        I like where this is going!
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                        • catuned
                          • Jun 2011
                          • 2324
                          #147
                          100% cool no doubt about it.
                          Work We Do
                          • deutschman
                            • May 2008
                            • 5958
                            #148
                            Originally posted by SkiFree
                            What brand? I cant make out the label. I'd like a set of these my self.
                            • SkiFree
                              • Jun 2011
                              • 2766
                              #149
                              Wanted something that wouldn't break when I try to bend stainless. Flare tool is Ridged (neat little ratchet action on top) and the bender is Imperial. Can't wait to start using them.
                              Also planning remote oil filter and cooler setup. Starting 90' off the block.
                              ADAMS Autosport
                              • deutschman
                                • May 2008
                                • 5958
                                #150
                                Thanks Andrew.
                                Your hands are on the wrong sides. lol
