M20B29 w/ Triple Webers into my '71 2002
  • LJ851
    • 7919
    #151
    Originally posted by deutschman
    Your hands are on the wrong sides. lol
    He could be lying on his back...
    Lorin
    The M30 is God's engine.
    • deutschman
      • May 2008
      • 5958
      #152
      Or he could be a mutant BMW genius!
        • 37832
        #153
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • SkiFree
          • Jun 2011
          • 2766
          #154
          Dunno, but here's a self portrait.
          ADAMS Autosport
          • deutschman
            • May 2008
            • 5958
            #155
            Baby Ruth?
            • SkiFree
              • Jun 2011
              • 2766
              #156
              Baby Ruth?
              The Goonies!
              Well, I've still been hoarding more and more parts. Still not moving very fast.
              Frank was nice enough to bring these for me! The M20's have a difficult time with headers into the 2002 with the framerail right there. If anything should works it's these. They tuck up nice and tight. Now off for some ceramic coating!
              While digging through our stash at work, I came across this new block. Still had the BMW tag on it. Should make for a good starting point, was certainly a nice little surprise.
              Am starting to play around with some new possible piston designs with our supplier ROSS. Starting with a fresh combustion chamber casting.
              Letting it set.
              Popped out.
              ADAMS Autosport
              • tinkwithanr
                • Jun 2010
                • 377
                #157
                Now that's exciting.
                I wish I'd known that my pistons were going to come back flat top when I ordered them... I definitely would have looked elsewhere.
                Tinker Engineering - 2014
                Mica - 2000 BMW 323i - The one that started it all
                Fiona - 1975 BMW 2002 - The Definition of Project Creep
                Heidi - 1988 BMW M5 - The piece of BMW history
                Silvia - 2013 Subaru WRX - Stock, for now
                • SkiFree
                  • Jun 2011
                  • 2766
                  #158
                  Trying to fix shortcomings as I can, hopefully this'll keep from any further potential disappointment. If anything it'll have to be listed as an option when it comes to fruition.
                  ADAMS Autosport
                  • Nick_S
                    • Apr 2011
                    • 3655
                    #159
                    Read this entire thread start till present. Incredible attention to detail and work have gone into this. It was exciting to read every new update. I can only imagine the feeling of getting this all together for the first time. Excellent work!
                    91 318is M50 swapped
                    05 Honda Pilot
                    24V swap thread
                    • SkiFree
                      • Jun 2011
                      • 2766
                      #160
                      Thanks Nick, some days i feel snails zooming by.
                      FUEL: kinda changed things around a bit here.
                      I've got nearly the entire fuel setup ready. Basically be running a low pressure electric Carter pump to the Malpassi adjustable regulator (need to tap in pressure gauge). up and over to a hot-rod style brazed fuel rail. Similar to the Jaguar setup below....
                      Neat story on the rail.... was looking all over for stainless braze T-fittings, couldn't find any. Then saw Stromburg Carbs (you hotrodders will be familiar) came out with a rail using the fittings I needed (picture below)!
                      So I email Clive there and he says, sure he's got 5 pieces left from prototyping and tosses them in the post for me from the UK for $25. I couldn't make them for that! Was pretty happy, plus I'll have a bit of a hot-rod connection going on. Now just waiting on the Cunifer tube and break out the Oxy-Acytelene torch!
                      IGNITION:
                      Just needing to do some wires and have whodwho do an ingition-only MS setup.
                      ADAMS Autosport
                      • SkiFree
                        • Jun 2011
                        • 2766
                        #161
                        Well pistons are now done ....
                        For wire routing with the wasted spark setup I wanted something that looked factory and not messy. Asked our ignition wire supplier to send me a set of disassembled 325i 8mm wires with longer, uncut, ends along with the HEI boots. I dremeled an opening on the other end of the loom and reversed the wire order (shrink wrap wire numbers were a nice bonus).
                        Mocked up on an extremely accurate engine bay reproduction .... if anybody else is running a wasted spark setup I have made these a repeatable part number with our supplier so just let me know (can also use the EDIS boots if needed). Now the last step for ignition is to go bug whodwho.
                        ADAMS Autosport
                        • deutschman
                          • May 2008
                          • 5958
                          #162
                          Very cool.
                          By the way. MSD headers (also in SoCal) fit well in an m20 2002.
                          • catuned
                            • Jun 2011
                            • 2324
                            #163
                            looking super!
                            Work We Do
                            CAtuned Feedback Page|FB CAtuned Page
                            http://www.catuned.com
                            • tinkwithanr
                              • Jun 2010
                              • 377
                              #164
                              I'm not sure if I'm upset or happy, you stole my idea for placement of the coils and reversing the run of wires in the stock holder!
                              On the plus side I can just order them from you now as opposed to having to make them by hand. I suppose I can't complain to much...
                              • SkiFree
                                • Jun 2011
                                • 2766
                                #165
                                Dang it, I forgot that's the way you were doing it, but I remember looking at your pics. Must have stuck in my subconscious. Well, when your ready email and I'll sell one to you for cost, since it was your idea.
                                As for the MSD headers, I'm pretty well acquainted with them. We were the ones who had them start making those in the first place. Won't go into it, but simply got tired of dealing with quality control issues. Now they're supplying another SoCal supplier.
                                Chris at only02.com called the other day for some bits, got talking and turns out he made some conversion mounts ..... couldn't resist.
                                ADAMS Autosport
