Pantless Spencys zinno ETA fix-up thread. ~NOW RUNS YAY~
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    #316
    the head of the bolt hadn't even hit the cam seal ring yet
    i wasn't just going ham on the thing lol. but the one that did snap seem'd to have suffered from heating and cooling rapidly, it was a rusty color, i take it was from the side closer to the thermostat port.
    • hfabricius
      • 608
      #317
      Bentley manual says 48-52 ft. lbs. Camshaft sprocket to cam, right?
      http://halden-fabricius.tumblr.com/
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        #318
        yessir.
        the torx 12 male bolt that goes into the camshaft.
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7283
          #319
          how would one go about torqueing that since it spins the cam?
          • hfabricius
            • 608
            #320
            Take an old timing belt and wrap in around that camshaft sprocket and use some vice grips to keep it tight. Similar to how a oil filter/strap wrench works. Ill try and pull the picture from the bentley pdf.
            EDIT: Got it.
            • Pantless Spency
              It's McRib time!!!
              • Feb 2011
              • 7283
              #321
              fuuu i just threw that out! lol
              • mbonanni
                • Sep 2011
                • 6236
                #322
                Originally posted by Pantless Spency
                yessir.
                Sorry thought big crankshaft bolt /:
                Tighten that shit down as much as possible, then install on car. hold crankshaft bolts tighten??
                • Pantless Spency
                  It's McRib time!!!
                  • Feb 2011
                  • 7283
                  #323
                  maybe a good idea^^^
                  • Pantless Spency
                    It's McRib time!!!
                    • Feb 2011
                    • 7283
                    #324
                    do you install the camshaft seal from the back of the cam to the head or once the cam is all the way in then slide the seal over it?
                    i checked the bolt and its submerged in the head :Fuck:
                    • hfabricius
                      • 608
                      #325
                      From the Bentley: Installation is the reverse of removal. Before installing the
                      camshaft, it should be thoroughly lubricated . Coat the camshaft
                      oil seal lip and the housing O-ring with motor oil before
                      installation. To prevent damaging the oil seal, wrap the front of
                      the camshaft with tape. If the oil supply tube was removed ,
                      tighten the fittings to 6 to 8 Nm (4.5 to 5 . 5 ft. lb.) . I nstall the
                      camshaft sprocket and the distri butor rotor adaptor so the
                      guide pin correctly aligns with the guide hole in the sprocket
                      and adaptor. Tighten the mounting bolt to 65 to 70 N m (48 to
                      52 ft. l b.) .
                      • Pantless Spency
                        It's McRib time!!!
                        • Feb 2011
                        • 7283
                        #326
                        hm i just read my chilton and i still dont have a clue.... (about the camshaft seal.)
                        • 5Toes
                          • 9836
                          #327
                          Today has been a successful day.
                          Hopefully you will have it in the car by Sunday?
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7283
                            #328
                            todays been a lot of fuckery.
                            seriously just wanna buy a b27 and drop it in.
                            • 5Toes
                              • 9836
                              #329
                              lol I didnt want to say it that way, chose to be sarcastic.
                              • Pantless Spency
                                It's McRib time!!!
                                • Feb 2011
                                • 7283
                                #330
                                toes im so frustereaaarted.
