Pantless Spencys zinno ETA fix-up thread. ~NOW RUNS YAY~
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    #166
    that blows :(
    but if the people im bringing are down ill roll witchu, as in a pack of e30's :D
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7283
      #167
      today i got a box :P
      inside was new o rings for my injectors.
      new blind plugs for my head.
      new valve stem seals.
      new camshaft seal.
      and a new distributor rotor!
      sweet.
      time to start building 8)
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        #168
        its my birthday :)
        • Steeler325is
          • Nov 2011
          • 79
          #169
          Happy Birthdaze!
          • Pantless Spency
            It's McRib time!!!
            • Feb 2011
            • 7283
            #170
            thanks mayne :)
            • Pantless Spency
              It's McRib time!!!
              • Feb 2011
              • 7283
              #171
              just finished putting in all new stem seals, and putting in all of the intake valves, need to do some cleaning of the exhaust valves then that is next.
              made sure to use plenty of assembly grease :)
              • cmybimmer
                • 894
                #172
                do it
                • mbonanni
                  • Sep 2011
                  • 6236
                  #173
                  or
                  • Pantless Spency
                    It's McRib time!!!
                    • Feb 2011
                    • 7283
                    #174
                    no wai!
                    • Pantless Spency
                      It's McRib time!!!
                      • Feb 2011
                      • 7283
                      #175
                      so i installed my new valve seals, and now i'm working on lapping my valves.
                      this is the first valve we did.
                      my friend showed me this way of doing it, said it was an "old motorcycle trick" hahah.
                      basically you put the valve in place, apply metal grinding compound (valve lapping compound) between the seat and the area of contact for the valve. then attatch a tight fitting soft compound tube around the stem of the valve, pull down and spin! every few seconds lift the valve to reseat it.
                      thoughts on the contact area of this valve and the method??
                      • LJ851
                        • 7919
                        #176
                        That is certainly not motorcycle specific, just a way to lap a valve without a suction cup tool from the top of the valve. It also saves you from having to clean all the deposits off the face of the valve . I would have left the seals off til after all the lapping was done to avoid all the trauma of the sharp keeper grooves having their way with the seals every time you remove and install the valve.
                        *Remove Dog Hair before assembling engine*
                        Lorin
                        The M30 is God's engine.
                        • Pantless Spency
                          It's McRib time!!!
                          • Feb 2011
                          • 7283
                          #177
                          hahaha i noticed that when i was looking at the photos, yes i will make sure there is no dog hair in there.
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7283
                            #178
                            lapping these valves is taking almost an hour on each one! anyone got a better method?
                            • Cabriolet
                              • 9620
                              #179
                              we tape the suction cup to a drill and go back and forth with that. takes about 15min per valve that way.
                              Much wow
                              I hate 4 doors
                              • Pantless Spency
                                It's McRib time!!!
                                • Feb 2011
                                • 7283
                                #180
                                been working on some valvessssss in my free time
