Pantless Spencys zinno ETA fix-up thread. ~NOW RUNS YAY~
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7284
    #586
    It's been a long time, a lot of work too. Needs a lot more work too hahahah
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7284
      #587
      Got the magnaflow installed. I like the noise but the fitment of it is alright, could be better.
        • 37827
        #588
        What size tires did you go with? They look a bit small. :(
        Classic BMW Specialists
        Santa Clarita, CA
        www.BimmerHeads.com
        • Pantless Spency
          It's McRib time!!!
          • Feb 2011
          • 7284
          #589
          They're definitely small for the set up.
          There some federals. 195/45/15
          • efficient
            • Feb 2012
            • 3312
            #590
            should have put some 205/50/15 on it.
            muffler looks out of place.
            • Pantless Spency
              It's McRib time!!!
              • Feb 2011
              • 7284
              #591
              yeah I should have got bigger tires. First time around with this lol.
              As for the muffler, it is kinda low but when your at normal viewing height, it's a lot different. I like it. It's as high as it can mount while being flush with the diving board.
              I've been thinking about going back and doing a y pipe with dual exit, no muffler.
              • Pantless Spency
                It's McRib time!!!
                • Feb 2011
                • 7284
                #592
                Just ordered a turner motorsport m20b27 chip, im excited.
                its +28 torque and +24hp.
                soooo if my rebuild is still in great shape (13k miles since new) I should be having figures like 150hp and 198 torque, which will be a lot of fun and smiles for me :D also rev limits raised to 5300 rpm.
                for $209 bucks to my door in two days, I couldn't be more pumped.
                • 2mAn
                  Señior Mod
                  • 20179
                  #593
                  Its probably not +20 peak, most likely in the areas where it drops off. Still a solid area under the curve is a solid area under the curve
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  -2006 Volkswagen Jetta TDI
                  Make R3V Great Again -2020
                  • Pantless Spency
                    It's McRib time!!!
                    • Feb 2011
                    • 7284
                    #594
                    yeah I'm no smarty when it comes to power figures, they describe that the engine will perform more powerfully in the upper rpms, as apposed to lack luster with the stock chip.
                    turner states +24hp @4500 RPM and +28 torque @4500 RPM.
                    If its not as good as it sounds, I'm sure ill at least be able to notice it and enjoy the extra power.
                    • 2mAn
                      Señior Mod
                      • 20179
                      #595
                      Yea, 4500rpms is close to redline on that little monster isnt it? Get a 3.25 LSD and you will enjoy it quite a bit. I miss my eta sometimes...
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • ak-
                        • 12422
                        #596
                        It'll make a noticeable difference. My brother bought his '85 ETA car with a Dinan chip without knowing and we kept putting 87 octane in it and it was always lazy at higher RPM's.
                        One day we threw a tank of 91 octane in it and the car noticeably woke up at high RPM's which made us think there was a chip inside, and sure enough upon opening the DME, we saw a Dinan labeled sticker on the chip.
                        Considering Dinan is pretty conservative, I expect nothing but good from Turner.
                        1991 325iS turbo
                        • Pantless Spency
                          It's McRib time!!!
                          • Feb 2011
                          • 7284
                          #597
                          I has a 3.25 LSD, and it is fun
                          Yeah I'm very excited.
                          • Pantless Spency
                            It's McRib time!!!
                            • Feb 2011
                            • 7284
                            #598
                            so im sort of half assed hunting for a 24v to build over winter for a swap, but i'm also kind of convinced to just keep the engine with 15k on it, and slowly piece together a turbo kit for the eta over winter.
                            • kronus
                              • Apr 2008
                              • 13014
                              #599
                              m50tu's are pretty cheap now
                              cars beep boop
                              • Pantless Spency
                                It's McRib time!!!
                                • Feb 2011
                                • 7284
                                #600
                                Yeah. Then I could upgrade with some s50 cams. A little hard to find though, or I could get some performance cams.
