24V IX SWAP (*56k* BEWARE!)
  • nrubenstein
    • 3148
    So, why hydroboost? Why not use the simpler, lighter and already extant iX hardware?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • MattM
      • Apr 2009
      • 931
      with the IX its not as easy to just 'rotate the engine 12* and make a custom transmission mount' because you have the transfercase mounted on the end which CANT rotate, and you have the oil pan that holds the differential which needs to be level....
      SO, you use the factory IX mount arms, which mount the engine at the same angle as the factory M20, but then the intake is super close to the booster mounting... not enough to fit any form of booster.
      In theory i could take the entire front drivetrain from an E34 IX and it would all work out...... but where do you find one of those on this side of the pond :(
      Heres my ghetto mock up oil pan...(never welded aluminium before this...)
      and a test fit i did a few weeks back with a scrap M50 block
      Full Build Thread Here
      • MattM
        • Apr 2009
        • 931
        so, i am trying to decide if i want to try OBD2, or if i should just convert the m52 to obd1?
        thoughts? Im going to check out an engine this thursday or friday.... :D
        • parkerbink
          • Jun 2004
          • 10134
          Very interesting. Good luck!
          • VRSTLE
            • Dec 2010
            • 146
            wow this is exciting
            • e30s50dan
              • Nov 2008
              • 2076
              subscribed
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
                • 34827
                Originally posted by Pantless Spency
                oh man has anyone rigged a 24v ix before? i've never heard of it until just now. awesome idea i'm in for this one, subbed.
                yes, many times. just not as often, obviously.
                • MattM
                  • Apr 2009
                  • 931
                  no where near as documented either....
                    • 34827
                    yeah, but as you know, the oil pan and brake/intake manifold are the two biggest issues. I'd like to do one myself if the extra weight didn't turn me off.
                    • MikeDE
                      • 1873
                      Did you bolt the pan to the block before welding?
                      Nice work BTW, I wish I had the space and time to do a swap like this.
                      -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
                      • longms
                        • Jan 2007
                        • 280
                        Looks awesome. Good luck with the build.
                        '91 318is Alpine II- || HR Sport || Bilstein Sport || Poly RTAB || Treehouse FCAB || Poly Motor Mount || Poly Tranny Mount || Poly Diff mount || IE Sway Bar || BA HP Coils/Wires || 19# Injectors || SSR Comps w/10mm spacers || Hawk Pads || Fog Delete || Magnaflow Exhaust || Z4 3.0 SSK ||
                        • MattM
                          • Apr 2009
                          • 931
                          sprayed the modified stuff.... now i want to do the entire bay...looks so much nicer :/
                          and yeah, the pan was fully bolted down for the majority of the welding
                          • MattM
                            • Apr 2009
                            • 931
                            Going to pull an engine out of a low mile 328 tomorrow
                            • oddis
                              • Jan 2009
                              • 53
                              Great project, subscribed!
                              Did the E28 hydrobooster fit directly onto the firewall mouting? I had to space it out with a adapterplate as it was coning in, and would'nt sit straight.
                              I know of some IXs over here thats been non-stock swaped with S38 turbo, S50 euro, M30 and M50.
                              E34 iX parts is the best solution as you say, somewhat more better durability/strengt. I've also heard about IX witch have used Nissan Skyline R34 parts, i think that was for the S38 turbo swap.
                              Even a guy from Finland running with 600hp/800Nm on stock transmission, diff and transferbox ( http://www.youtube.com/watch?v=RmswE..._order&list=UL )
                              Did find this these articles on e30.de:
                              S50 euro (same block size as M50)
                              S38:
                              http://wp1016621.wp027.webpack.hoste...604/f01604.htm
                              M30:
                              Google translate and it's a lot of info there, hope they can help you :)
                              S54 iX swap could be fun ;) It shouldn't be hard to find one over there ;) Easy plenum mod if you had to modifiy it to save space also. Indivual throttlebodies minimize the need for big space.
                              BMW 1000HP Turbo Videos
                              • MattM
                                • Apr 2009
                                • 931
                                Wow, thanks for the links, theres a local guy who has 60k KM S38 that we joked about putting into the IX, but had never even heard of that, and normal S38 swaps are still a challenge
                                the hydroboost fits the firewall fine(im using E24) I havent hooked the pedal up yet and it seems the rod is a little long, so i will update when i cross that bridge.
