87' Delphin 325is LS1: Went to Paint
First peeks inside look good!
1987 Delphin 325IS
LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
Build Thread
1993 alpine 2 325IC
•Ground control coilovers•16" BBS RS• momo woodgrainComment
Moving along, driveshaft modded and ready for install
Oil pan patch bent ready for welding
Water pump pulley pulled out 3/8" and tack welded so it won't move
Mustang gt hydro boost
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
Hydro boost n shit all modded ready to go
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
Got me a late model valance to put on the rear of my car:
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
Oil pan is ready for some bead laying
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
Got me a set of headers
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
Beaded up the pan
Got the correct headers
Ordered steering shaft solution
Got my wiring and relay/fuse setup
Shot of the corner where I'm stacking everything up
You can see the new rad behind the trans there tooYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
Nice work! Keep it up with picsE30-LS1 aka. 357is
email us to pick up our LS1 swap guide
E30-LS1 KITS now available!!
E30LS1@gmail.com
e30ls1.com
Will do, your guide is great and the parts you made are high quality as well! Do you think I can fit 3" pipe from the headers? I wont be running cats, and I noticed 3" pipe fits pretty nice through the trans brace. I want to run 3" from each header to a 4" oval exhaust with a cutout or something. Also there are some parts that are missing in your master parts list that I found while reading though each section.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
Starting the cam swap. I decided to go with a Texas Speed & Performance 228r cam, beehive springs and chromoly pushrods. Good for a 50hp gain.
This engine is so clean inside it's Crazy!Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
1987 Delphin 325IS
Build Thread
1993 alpine 2 325IC
